Wireless
8635 Discussions
Ubuntu 20.04 (kernel 5.4.0-80-generic) - Unstable (and slow) wifi
lcgodoy
Hi!
My wireless device is an Intel Corporation Wireless 8265 / 8275. Although my Bluetooth is working fine, it looks like whenever I'm using a Bluetooth device the internet connection is even worse. I'm using an ASUS laptop, the drivers and BIOS were updated recently (less than a year ago).
In the last few days, my internet connection has been painfully slow and unstable. At first, I thought it was a problem with the provider, however, when using Windows on another computer the internet is working perfectly fine. I could not find any solution for this problem and I do have reasons to believe I'm not the only one experiencing this issue.
Some "diagnostics" are found below:
> modinfo iwlwifi
filename: /lib/modules/5.4.0-80-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-ty-a0-gf-a0-50.ucode
firmware: iwlwifi-so-a0-gf-a0-50.ucode
firmware: iwlwifi-so-a0-hr-b0-50.ucode
firmware: iwlwifi-so-a0-jf-b0-50.ucode
firmware: iwlwifi-cc-a0-50.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-50.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-50.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-50.ucode
firmware: iwlwifi-Qu-b0-jf-b0-50.ucode
firmware: iwlwifi-Qu-c0-hr-b0-50.ucode
firmware: iwlwifi-QuQnj-a0-hr-a0-50.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-50.ucode
firmware: iwlwifi-QuQnj-f0-hr-a0-50.ucode
firmware: iwlwifi-Qu-a0-jf-b0-50.ucode
firmware: iwlwifi-Qu-a0-hr-a0-50.ucode
srcversion: E8E9F5689D56ED765B15F2A
alias: pci:v00008086d00007AF0sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 5.4.0-80-generic SMP mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: **********
sig_hashalgo: sha512
signature: ***
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm: nvm_file:NVM file name (charp)
parm: lar_disable:disable LAR functionality (default: N) (bool)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: 0 (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
> lsmod | grep iwlwifi
iwlwifi 331776 1 iwlmvm
cfg80211 704512 3 iwlmvm,iwlwifi,mac80211
> dmesg | grep iwlwifi
[ 3.930373] iwlwifi 0000:02:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.930384] iwlwifi 0000:02:00.0: Found debug configuration: 0
[ 3.931189] iwlwifi 0000:02:00.0: loaded firmware version 36.77d01142.0 op_mode iwlmvm
[ 4.078576] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 4.088197] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.089360] iwlwifi 0000:02:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 4.148219] iwlwifi 0000:02:00.0: base HW address: a0:af:bd:c1:a8:fe
[ 4.590164] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 7.408915] Modules linked in: cmac algif_hash algif_skcipher af_alg bnep snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio mei_hdcp intel_rapl_msr snd_hda_intel snd_intel_dspcfg snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi x86_pkg_temp_thermal intel_powerclamp coretemp snd_seq kvm_intel iwlmvm joydev snd_seq_device kvm nouveau(+) crct10dif_pclmul mac80211 snd_timer libarc4 ghash_clmulni_intel snd aesni_intel btusb iwlwifi uvcvideo crypto_simd btrtl asus_nb_wmi btbcm cryptd asus_wmi input_leds btintel glue_helper videobuf2_vmalloc rapl i915 sparse_keymap serio_raw wmi_bmof videobuf2_memops mxm_wmi bluetooth soundcore intel_cstate videobuf2_v4l2 ttm cfg80211 videobuf2_common ecdh_generic mei_me ecc hid_multitouch drm_kms_helper intel_xhci_usb_role_switch mei i2c_algo_bit intel_pch_thermal roles processor_thermal_device fb_sys_fops syscopyarea sysfillrect sysimgblt intel_rapl_common intel_soc_dts_iosf int3403_thermal
[ 7.757524] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 7.898881] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 7.967326] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[ 36.112247] Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg bnep snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio mei_hdcp intel_rapl_msr snd_hda_intel snd_intel_dspcfg snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi x86_pkg_temp_thermal intel_powerclamp coretemp snd_seq kvm_intel iwlmvm joydev snd_seq_device kvm nouveau crct10dif_pclmul mac80211 snd_timer libarc4 ghash_clmulni_intel snd aesni_intel btusb iwlwifi uvcvideo crypto_simd btrtl asus_nb_wmi btbcm cryptd asus_wmi input_leds btintel glue_helper videobuf2_vmalloc rapl i915 sparse_keymap serio_raw wmi_bmof videobuf2_memops mxm_wmi bluetooth soundcore intel_cstate videobuf2_v4l2 ttm cfg80211 videobuf2_common ecdh_generic mei_me ecc hid_multitouch drm_kms_helper intel_xhci_usb_role_switch mei i2c_algo_bit intel_pch_thermal roles processor_thermal_device fb_sys_fops syscopyarea sysfillrect sysimgblt intel_rapl_common intel_soc_dts_iosf
[ 46.218120] Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg bnep snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio mei_hdcp intel_rapl_msr snd_hda_intel snd_intel_dspcfg snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi x86_pkg_temp_thermal intel_powerclamp coretemp snd_seq kvm_intel iwlmvm joydev snd_seq_device kvm nouveau crct10dif_pclmul mac80211 snd_timer libarc4 ghash_clmulni_intel snd aesni_intel btusb iwlwifi uvcvideo crypto_simd btrtl asus_nb_wmi btbcm cryptd asus_wmi input_leds btintel glue_helper videobuf2_vmalloc rapl i915 sparse_keymap serio_raw wmi_bmof videobuf2_memops mxm_wmi bluetooth soundcore intel_cstate videobuf2_v4l2 ttm cfg80211 videobuf2_common ecdh_generic mei_me ecc hid_multitouch drm_kms_helper intel_xhci_usb_role_switch mei i2c_algo_bit intel_pch_thermal roles processor_thermal_device fb_sys_fops syscopyarea sysfillrect sysimgblt intel_rapl_common intel_soc_dts_iosf
[ 4470.012853] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 4470.148543] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ 4470.218212] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[ 5212.966489] Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg bnep snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio mei_hdcp intel_rapl_msr snd_hda_intel snd_intel_dspcfg snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi x86_pkg_temp_thermal intel_powerclamp coretemp snd_seq kvm_intel iwlmvm joydev snd_seq_device kvm nouveau crct10dif_pclmul mac80211 snd_timer libarc4 ghash_clmulni_intel snd aesni_intel btusb iwlwifi uvcvideo crypto_simd btrtl asus_nb_wmi btbcm cryptd asus_wmi input_leds btintel glue_helper videobuf2_vmalloc rapl i915 sparse_keymap serio_raw wmi_bmof videobuf2_memops mxm_wmi bluetooth soundcore intel_cstate videobuf2_v4l2 ttm cfg80211 videobuf2_common ecdh_generic mei_me ecc hid_multitouch drm_kms_helper intel_xhci_usb_role_switch mei i2c_algo_bit intel_pch_thermal roles processor_thermal_device fb_sys_fops syscopyarea sysfillrect sysimgblt intel_rapl_common intel_soc_dts_iosf
> dmesg | grep “no suitable firmware found!”
I have already tried disabling 802.11n, disabling IPv6 support, and also the power save options. Nothing seems to work.
Any suggestions?
DeividA_Intel
Hello lcgodoy,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Run the following commands and send us the outcome:
· modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
· lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
· To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
· dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (API mentioned in the dmesg).
· Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
4. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
DeividA_Intel
Hello lcgodoy,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello lcgodoy,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
My recommendation would be to check with the laptop manufacturer and also the Linux distributor for further instructions.
Deivid A.
