Wireless
8624 Discussions
Ubuntu 20.04 (kernel 5.8.0) and Wi-Fi 6 AX200 is unstabe and doesn't show 2.4G networks
rgiometti
in these last days I start notice a strange behavior on my Ubuntu 20.04 (kernel 5.8.0-45-generic) which manages a Wi-Fi 6 AX200 (rev 1a).
Network connection is very unstable with frequent disconnections and also I notice that the system is not able anymore to see 2.4G networks! Just 5G networks are displayed during a network scan.
Attached are modinfo information and trace-cmd output. Please, let me know if you need more info to investigate this really strange issue.
Thanks in advance,
Rodolfo
DeividA_Intel
Hello rgiomett,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is the Bluetooth working?
4. Is this a laptop or desktop computer?
5. Have you update your drivers and BIOS?
6. Did you noticed the issue after a system update?
7. Run the following commands and send us the outcome:
· modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
· lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
· To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
· dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (api mentioned in the dmesg).
· Please visit here: h ttps://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
8. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
DeividA_Intel
Hello rgiometti,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello rgiometti,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
