Wireless
8995 Discussions
Ubuntu driver for Intel AX201
Not applicable
Hello. I installed Ubuntu on my laptop HP ProBook, but I can't connect to Ubiquity AP 6 Lite. I checked that driver for wi-fi adapter recognized not correct, see output data:
sudo lshw -C network
*-network
       description: Wireless interface
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlp0s20f3
       version: 20
       serial: [i hide it]
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.13.0-27-generic firmware=63.c04f3485.0 QuZ-a0-hr-b0-63.u ip=192.168.1.62 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: iomemory:600-5ff irq:16 memory:600324c000-600324ffff
I tried:
sudo apt-get update and sudo apt-get upgrade but my Ubuntu has actual version and do not have fresh updates.
How to update or actualize driver?
JosueO_Intel
Thank you for posting on the Intel communities.
In this case, it is important for you to know that the Linux drivers are part of the upstream Linux* kernel. They're available through the regular channels, distributions, or the Linux* kernel archives. We support the use of the drivers only in the kernel version the driver was a part of. Please refer to the table by this link for a list of supported devices by the iwlwifi driver.
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
For installing this driver, please follow the next instructions:
  1. Copy the files into the distribution-specific firmware directory, /lib/firmware.
  2. If the directory doesn't work, refer to your distribution documentation.
  3. If you configure the kernel yourself, make sure firmware loading is enabled.
Josue O.
JosueO_Intel
We have not heard back from you, so we will close this thread. In case you need assistance with installation or driver download, please contact your Linux vendor to get specialized support.
Josue O.
