Wireless
8667 Discussions
Ultimate-N 6300
I've looked at the specs, but can't find an answer to this so I hope that someone here can help me out
My router uses channel bonding at 2.4 GHz which means it is capable of a 300 MHz connwction. I was hoping that my new laptop with the Ultimate-N 6300 would be able to connect at this rate, but it only seems to connect using a single channel and not the two bonded channels. Is this correct?
I've been working on this but still can't get the 6300 to work in two-channel mode. Does anyone know about this?
