Wireless
8667 Discussions
unable to connect using wireless connection
Since successfully restoring my laptop to factory settings I have been unable to connect using my Intel PRO/Wireless 3945ABG Network Connection.
Initially it worked, but after a while it stopped. I have completed several system restores, and the wireless connection works for a few days. On the last occasion (after installing windows updates) I received the dreaded blue screen and have been unable to connect.
I am not sure if it is related to installing new windows updates as prior to restoring to factory settings I had no issues with my wireless connection.
I am able to connect using the ethernet cable and I am currently able to connect using Pluscom wireless usb adapter.
I would be grateful for any suggestions as its driving my insane.
I am that frustrated I attempted a final restore to factory settings and now my wireless adapter is disabled and i cant enable it.
I am using the fujitsu siemens amilo pi 2515 notebook.
netgear dg834g router
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . :
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8101 Family PCI-E Fast Etherne
t NIC (NDIS 6.0)
Physical Address. . . . . . . . . : 00-03-0D-84-69-82
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::5d3e:14dd:2a75:953%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 29 April 2011 12:54:38
Lease Expires . . . . . . . . . . : 30 April 2011 12:54:37
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 134218509
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : isatap.{40F4E25A-FA42-41FC-B400-812BFD587
9AC}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.0.2%11(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
The 3945 wireless adapter didn't show up in ipconfig. Here are some things you can try ->
- go to device manager to check if driver for wireless adapter is installed properly, if not, you'll need to download and install the driver
downloadcenter.intel.com -> to download the driver and software, just select the appropriate product model and OS
- check for any on/off button around the laptop, sometimes it is in function keys, such as Function + F2
