Wireless
8721 Discussions
Unable to install any drivers for my Intel 6205 WiFi (Is it fake?)
Hi all,
This is my first post here, I would like some help regarding a newly bought WiFi card.
I have just bought a Intel Centrino Wireless-N 6205 WiFi card. The packaging and the labels all look correct, however its hardware ID contains an ID that is not present in any of the Intel drivers that I could find.
The code is VEN_8086&DEV_008A&SUBSYS_00008086
From the Intel driver's INF, it seems that VEN_8086 and DEV_008A usually refers to the Intel Wifi 1030 card. However, even so, none of the combination matches as the SUBSYS number is not the same.
My question is: Is this card simply too new, and therefore the drivers supposed to support it is not out yet? Or it is simply a fake card?
The laptop that I am trying to install it on is a Sony VAIO SB-series laptop (Sandy Bridge based; Windows 7 x64). I have also tried the same card on a Dell, but the PCI code shows up to be the same and thus drivers could not be installed.A screenshot showing the Hardware ID: http://farm6.static.flickr.com/5143/5597021622_85a4189615_o.png http://farm6.static.flickr.com/5143/5597021622_85a4189615_o.png
Thanks in advance!
--Jenius
DSilv11
Valued Contributor III
What is the other network controller in the system?
The pci id VEN_8086&DEV_008A&SUBSYS_00008086 Is strange,
Intel product N 1030 network adpt OEM
GENeric 1030_BGN wireless adpt.
PCI\VEN_8086&DEV_008A&SUBSYS_53078086 or
PCI\VEN_8086&DEV_008A&SUBSYS_53058086 ;
Dell_1030_BGN
PCI\VEN_8086&DEV_008A&SUBSYS_53278086
PCI\VEN_8086&DEV_008A&SUBSYS_53258086
As you can see, the the driver package contains a custom version for the generic and for a DELL specific version.
Other OEM may post there own driver.
The 6205 should have an ID of PCI\VEN_8086&DEV_0082&SUBSYS_13018086
Since it appears to be the right driver, with the wrong device ID you could probleby do a force load and it would work, But I think I would just return it or try the warranty support line.
One of the network guys on here may have more info.
DSilv11
Dell_1030_BGN
Thanks pal,
Those are my exact thoughts too! =)
Now negotiating a return of the product.
