Wireless
8658 討論
Unable to install the latest version of Intel Killer Performance Suite
NicGroover
初學者
19,139 檢視
Unable to install the latest version of Intel Killer Performance Suite Error code -858993460.
Even after downloading the installation does not want to launch.
0 積分
29 回應
VonM_Intel
主席
16,841 檢視
Hi, NicGroover.
Thank you for posting in our Community.
Error code -858993460 Technical difficulties with the installation of the Intel Killer Performance Suite can be tricky to diagnose. Have you encountered this error code before with other installations, or is it specific to the Intel Killer Performance Suite? Understanding whether this is a recurring issue or isolated to this particular software could provide valuable insight into troubleshooting the problem. If you have done any other tests please let me know the details so we don't cover the same ground twice.
Furthermore, I'd like to explore further and confirm details such as the wireless models, exact driver versions, and any system errors present. Utilizing the Intel SSU tool will allow us to gather comprehensive information about your system configuration, potentially aiding in pinpointing the root cause of this issue.
Looking forward to your response. Have a nice day!
Von M.
NicGroover
初學者
16,831 檢視
Hi Von M.
Thank you for your reply.
I only encounter this problem with the Intel Killer update. I haven't tried uninstalling Intel Killer and reinstalling it.
Attached is the SSU diagnostic.
thank you for your help.
Nic
olegeezer
新手
11,149 檢視
Don't expect a solution to your problem with the Killer Performance Suite. I have tried for months to get Intel, Asus, or Microsoft to find and fix these problems with Killer Performance Suite 36.24.1064. I can install it but it does not display the download and upload speeds and there is no way to access any useful settings as has been suggested. I have updated every driver and firmware that my Asus requires and updated all drivers and firmware for my netgear RS700S router. I have the latest version of Windows.....24H2. This 36.24.1064 is a broken Suite which no real effort has been put forth to fix by Intel, Asus, or Microsoft. Good luck getting it to work.
Matt
VonM_Intel
主席
16,810 檢視
Hello, NicGroover.
Thank you for informing me and for sharing the SSU report. Analyzing the SSU diagnostic will help us gain a better understanding of your system configuration. We'll examine the data provided and work on resolving the issue. While we're reviewing the data, if feasible, could you please send us screenshots that display the precise error messages encountered during the installation process? This will enable us to offer the most accurate resolution to address the issue.
Von M.
NicGroover
初學者
16,790 檢視
Hi Von M.
I uninstalled Intel Killer properly to try to resolve the problem but it was impossible to reinstall it with the latest version.
I already encountered this problem a few months ago but forgot how I managed to solve it.
Kind regards.
Nic
NicGroover
初學者
16,787 檢視
VonM_Intel
主席
16,748 檢視
Hello NicGroover,
Thank you for providing the screenshots illustrating the issue. I understand that you attempted to resolve it by uninstalling, but encountered difficulties reinstalling with the latest version. In some cases, issues with the Intel® Killer™ Performance Suite can be resolved by executing a clean install, rather than updating with the latest version while an older version remains installed.
Let's try a clean installation of the Intel Killer Performance Suite. Please follow these steps:
  1. Download the latest installer for your version of Windows*
    • Note: If you do not have Internet connectivity on the affected computer, you may need to download the appropriate installer to removable media, such as a USB thumb drive, using another device. If this is necessary, remember to copy the files to the affected computer before you begin, as the installer may not work correctly if started from external media. If you're using Windows® 10 Version 1803 and higher with one of the active Intel Killer Adapters, should download the installer from the Download Center.
  2. Uninstall the Intel Killer Performance Suite manually:
    1. Go to your Windows search bar.
    2. Type in and go to Apps & features.
    3. Find the Intel Killer Performance Suite from the list.
    4. Click the Intel Killer Performance Suite and select the option to uninstall.
    5. Restart your machine by clicking Start > Power > Restart.
  1. Once your computer has rebooted, access your temporary files folder and delete the contents
    1. Click Start.
    2. Type %temp% and press Enter. Your temp folder should open.
    3. Delete all files in the temp folder. These are all temporary install files and are safe to delete. If you receive a prompt saying that a file cannot be deleted, you can safely select Skip All.
    4. Close the temp folder
  2. Run the installer that you downloaded for the Intel Killer Performance Suite.
  3. Select Complete when asked to Complete Install or Custom Install. The software package only installs the Intel Killer Performance Suite and the device drivers.
  4. Follow the remaining prompts to complete the installation.
  5. The final part of the installation will involve forwarding you to the Microsoft Store* to download the Killer Performance Suite user interface. This is required to use the Intel Killer Performance Suite.
  6. Restart your machine if the installer requests a restart.
  7. Test to see if the issue is resolved.
Note: If you cannot install the latest Intel Killer Performance Suite because you receive an error that says that the current package cannot be installed with one of our older packages, even after using this clean install guide, or if you encounter any other issue with installing the latest Killer Performance Suite click here for our guide for using the Microsoft Tool for issues that block a program from being installed.
Moreover, kindly visit this link that can also help to fix the issue:
Von M.
NicGroover
初學者
16,732 檢視
Hi Von M.
I followed all the instructions but unable to install the latest version KillerPerformanceSuite_35.24.5373_Win10-11x64
Installation does not start.
Best regards.
Nic
VonM_Intel
主席
16,667 檢視
Hello NicGroover,
Thank you for getting back to us. Despite following the recommendations we provided, the issue with installing KillerPerformanceSuite still persists. We will need to conduct further research on this matter and update this thread with our findings once available.
Von M.
VonM_Intel
主席
16,516 檢視
Hello NicGroover.
Thank you for patiently waiting.
I recommend installing this driver: https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html because the Killer Wireless-AC 1550 is based on the Intel 9260 chipset. Additionally, the SSU logs you provided indicate the presence of 9260NGW.
Von M.
NicGroover
初學者
16,505 檢視
Hello Von M.
I installed the drivers provided without encountering any problems and I updated my Intel Drivers and Support Assistant. The alert disappeared after restarting the Laptop.
However, I still cannot reinstall the Intel Killer application.
My Laptop works without Inte killer so I will leave it as is.
Thank you for your help.
Best regards.
Dominique
VonM_Intel
主席
16,399 檢視
Hello NicGroover.
Thank you for the update. I'm glad to hear that installing the drivers and updating Intel Drivers and Support Assistant resolved the initial alert after restarting your laptop. It's good to know your laptop is functioning well without it for now. Regarding the Intel Killer application, since we successfully installed this driver, and updated the Intel Drivers Assistant the issue was resolved, we'd like to know if you tried again the uninstallation and re-installation of the Intel® Killer™ Performance Suite. You may visit the links below for guidance:
Please let us know if these steps resolve the issue or if you encounter any difficulties along the way.
Von M.
NormanS_Intel
主席
16,301 檢視
Hello NicGroover,
I wanted to check if you had the chance to review the information we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Norman S.
NicGroover
初學者
16,294 檢視
I did the driver update from the Driver Assistant, which was done well. There is no longer an alert.
However, it is still impossible for me to instal Intel Killer Performance Suite, the click on the installation program does not launch any installation. I have no Killer Performance Suite program in my applications.
Thank you.
Best regards.
Dominique
VonM_Intel
主席
16,266 檢視
Hi, NicGroover.
Thanks for the reply. Seems like the driver update went smoothly, but, oddly, the Killer Performance Suite isn't installing. Let's troubleshoot that. Have you checked if there are any error messages or logs when you try to launch the Killer Performance Suite installer? If possible, kindly send us a screenshot or a video recording that shows when you're trying to install the Intel Killer Performance Suite file. This could help us isolate the installation issues with the Intel Killer Performance Suite.
Just to confirm, did you download the installer from the official Intel Website, and is it compatible with your operating system version? If so, may we know the exact version you're trying to install? This could help us in identifying the issue more accurately.
Von M.
VonM_Intel
主席
16,186 檢視
Hi, NicGroover.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
NicGroover
初學者
16,180 檢視
Hello Von M.
I can't install the verion KillerPerformanceSuite_35.24.5373_Win10-11x64. No error message, only the application does not start.
My Windows 11 is up to date and until this problem of updating Intel Killer drivers, the program worked without any problems.
Attached is a video of the program that I can't launch.
Best regards.
Dominique
VonM_Intel
主席
16,127 檢視
Hi, NicGroover.
Thank you for the update. I appreciate you attaching a video demonstrating the problem. This will help us better understand the issue you're facing. I viewed the screen recording and saw that there's no specific error message; the application simply does not start. Given that your Windows 11 is up to date and the program was previously functioning correctly before the Intel Killer driver update problem, this issue is indeed unexpected.
At this point, Let me investigate this matter further to determine the root cause and provide you with a resolution as soon as possible.
Thank you for your patience while we look into this.
Von M.
VonM_Intel
主席
16,021 檢視
Hi, NicGroover.
Thank you for patiently waiting. Upon coordination, the current driver was v23.40.1.1 but the DC was v23.40.0.4. We'd like to know, what is the reason to install or upgrade from IDSA? Is there any issue with the wireless connection for v23.40.1.1?
Additionally, I'm interested in knowing the versions of your Killer Networking Software app and device manager. You can send us a screenshot similar to the example below. This information will assist us in pinpointing the issue effectively.
Von M.
NicGroover
初學者
15,987 檢視
Hello Von M.
Thank you. I enclose a copy (screeshot) of my version of the Intel Killer Performance Suite driver. It works smoothly. Only I can reinstall the application.
I assume that it is not essential.
Best regards.
Nic
回覆
