Wireless
8899 Discussions
W880 Wi-Fi module compatibility
nikoszav
I have an Asus ET500i PC with a W880 chipset, Intel 265 CPU (Arrow Lake-S, 65W), ECC memory and Windows 11 operating system.
Does anyone know up to what level of Intel Wi-Fi module is supported:
Intel AX211 ?
Intel BE201 ?
Intel BE211 ?
n_scott_pearson
800 Series chipsets support CNVio, CNVio2 and CNVio3 devices, so all of these should be supported.
Frankly, I think you should stick with the non-CNVi cards: AX210 or BX200, but that's just me (who has stared at most complaints filed here for many years).
Hope this helps,
n_scott_pearson
Hope this helps,
nikoszav
Thanks for you reply Scott.
What is your complaint with the CNVioX versions of the modules?
If I go for a BE200 shall I need a separate USB cable for the Bluetooth part?
n_scott_pearson
What's my complaint? I have none myself. I am referring to the many complaints specific to CNVi module usage that I have seen here over the years.
As for the second question, the M.2 Type E connector, even if it includes CNVi support, still has support for USB included.
