Wireless
9026 Discussions
WIFI connection problem/Slow speed
AVana1
Sometimes it connects to router but internet is like 20 kbps, speed test: http://www.speedtest.net/result/2746428758.png http://www.speedtest.net/result/2746428758.png . More times it says that: windows was unable to connect Edimax(router).
Troubleshooting says that problem is with WI-FI adapter or access point.
I tried:
Power saving options
Windows repair and reinstalling
Transmit power to High
Newest WI-FI updates(Bios update included)
__________
Laptop Dell Xps 15 L502x
adapter: Intel(R) Centrino(R) Wireless-N 1000
__________
WLAN works - Perfectly
Windows Network diagnostics says - Your computer appears to be correctly configured, but the device or resource (DNS server) is not responding
Recently I disassembled my laptop to clean from dust. Also changed termo pasta for cores. Can this effect wifi? p.s. while assembling pc all wires were connected correctly. Do I need re-assemble it again to check it out?
So what solutions u can give me? Any Idea?
Auris
Jose_H_Intel1
Hello Auris,
It seems to be the issue is specifically related to your internet connection or configuration. It does not seem to be related to the wireless adapter or its local connection.
Most of the times the DNS is set to automatic, unless your Internet Service Provider gives you a specific configuration; therefore you may check with them regarding your internet connection.
You may verify your wireless adapter DNS settings from Control Panel, Network and Sharing Center (Network and Internet), double click the Wireless Network Connection in use and then click on properties, then double click Internet Protocol Version 4. It is also a good idea to check the router's configuration and update its firmware.
You may also see your local network (not the internet connection) has a higher transfer rate by running the following command in CMD:
netsh wlan show interfaces
Even though the integration of other components does not necessarily affect the wireless adapter we strongly recommend checking about this with the computer manufacturer since Intel Wireless Adapters are meant to be professionally installed by Original Equipment Manufacturer (OEM) technicians.
I hope this information helps.
