Wireless
8782 Discussions
WIN10 1803 7265 接有线网之后无线网会自动断开
凡徐
有没有人遇到过,最新的windows 1803版本,接上有线网,无线网会自动关闭,而且手动打开WLAN,还是会自动断开。拔掉有线网之后,WLAN就恢复正常,再插网线依然会挤掉无线网。
Hello 我的二三事,
As per our translation app, we understand you're having issues with the adapter switching feature in Windows® 10.
If you connect to a Wired network, your WiFi becomes disabled.
If you try to re-enable while still connected to wired network, it is disabled again automatically.
If you disconnect from wired network, your WiFi is re-enabled automatically.
This is an expected behavior, and operating system feature, introduced in Windows 7* called "adapter switching."
Adapter switching is a feature that enables a system to have a mutually exclusive relationship between an 802.3 (wired/Ethernet) and an 802.11 (wireless) connection. The adapter switching feature helps to enable network access to the system through only one interface in the system between wireless and wired adapters.
We found a couple of articles which may help you, if followed in reverse:
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
- https://social.technet.microsoft.com/Forums/windows/en-US/0e550e12-8ac3-49d5-9e17-1f67c5935222/disable-simultaneous-use-of-wifi-and-ethernet?forum=w7itpronetworking Disable Simultaneous Use of WiFi and Ethernet
- https://www.itechtics.com/5-ways-automatically-turn-off-wifi-ethernet-lan-cable-connected/ 5 Ways To Automatically Turn Off WiFi When Ethernet LAN Cable Is Connected
Carlos A.
