Wireless
8659 Discussions
What Intel WiFi card did I buy?
HBeno
I just received my Intel Celeron Advanced-N 6200 WiFi-Card. I installed this in my ASUS 73JW laptop.
Card shows up in Device manager as Network Adapter. However NO drivers seem to work. I have tried everything including a fresh OS-install
I run Win7 Ultimate 64-bit.
Card shows this as DeviceID:
PCI\VEN_8086&DEV_422B&SUBSYS_00008086&REV_1A
PCI\VEN_8086&DEV_422B&CC_028000
Someone wrote in another thread that this info is for a 6300 card. Can someone verify this?
I think card should be ok bec it shows up in the manager.
I know others that got this card to work in the G73-series from ASUS:
Thanks for all help // Z
Jose_H_Intel1
Hello ZnowDog.
Please note that Intel Wireless Adapters are meant to be professionally installed by Original Equipment Manufacturer (OEM) technicians on certified systems only due to different regulations explained in the article below.
We recommend contacting the Original Equipment Manufacturer (OEM) to determine which product is approved for use in your computer.
Only your system manufacturer is entitled to provide the list of validated and certified adapters that are compatible with your system and the proper means to do the hardware exchange for you.
Regulatory information regarding hardware installation or upgrade
http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm
Why doesn't my laptop recognize my new Intel® wireless adapter?
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
Jose_H_Intel1
Hello ZnowDog.
