Wireless
8521 Discussions
Why WiFi 5 speed decreased than overall when connecting multiple devices ??
EngHosam
there is only one 5ghz in my region, and WiFi 5 (ac 2x2) has overall speed in range at 72 MB/s for a 2x2 MiMo device, but when connecting two devices (xiaomi pad 5 and AX201) overall speed decreases from72 to 40, it becomes (30 MB/s in AX201, and 10 MB/s in my xiaomi pad 5),
overall speed decreased from 72 to 40 !!
Jean_Intel
Hello @EngHosam
I would like to have more information regarding your issue, so please provide me with an answer to the following questions:
  • When did it start to happen?
  • Are you able to get the 72 MB/s speed when you connect only one device?
  • Can you replicate the issue using other devices on the network?
  • Have you checked if this issue happens on different networks?
  • What Operating System version are you using on your device with the AX201?
  • Is this a new computer? If so, have checked with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  • Is this the AX201 the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Looking forward to hearing from you.
Jean O.
Jean_Intel
Hello @EngHosam
I hope you are doing fine
Also, I found another thread under your username with a similar description and issue. The tread mentioned is the following: https://community.intel.com/t5/forums/forumtopicpage/board-id/wireless/message-id/40449#M40449.
Let us know if both threads are requesting support for the same issue, as well as if you still need assistance.
Jean O.
Intel Support Technician
Jean_Intel
Hello @EngHosam
Hope you are doing well.
Jean O.
Jean_Intel
Hello @EngHosam
Hope you are doing fine
Jean O.
