Wireless
8845 Discussions
Why my Intel BE200 not support Wi-Fi7?
huahua
OS:Windows 11 Enterprise 24H2 26100.3194
Intel Driver: 23.110.0.5
AP:xiaomiBE70000, QCN6224(not support 6G),  it is wi-fi7 capable, WPA3 encryption
when I connect Intel BE200 to AP, it always work in wi-fi6 mode
JeanetteC_Intel
Hello huahua,
Installation or use of Intel® Wireless Adapters is subject to country-specific legal regulations. Some countries require the Intel® Wireless Adapters to be certified with the antenna that is intended to be used together in the system, while some countries require the Intel® Wireless Adapter to be certified at the full system level.
If the manufacturer doesn't have the necessary approvals, the party installing the device is responsible for approvals. Installing adapters in an unauthorized system may be illegal. The end user is not authorized to install the Intel® Wireless Adapters (except the retail products below). Only the manufacturer or its authorized representative can install the adapters.
Since you have already performed the integration, it is also important to understand that it may not work due to hardware or software compatibility issues or dependencies.
Intel is a supplier of laptop components and does not manufacture or sell complete laptop systems. Your system manufacturer may have altered the features, incorporated customizations, or made other changes to the software or hardware packaging they provide.
I highly recommend contacting your system manufacturer support to get help with the proper installation of their latest wireless drivers, and/or get help if help identify if the network card is faulty.
I hope these helps.
JeanetteC.
JeanetteC_Intel
Hello huahua,
To get better understand of this issue, please help share the following information, so I can further check and isolate the problem.
1) Is your system device new and trying to complete initial setup/configuration with your AP (Xiaomi BE70000)?
*If system was previously working, what changes has been made before getting the issue?
2) Can you share your system configuration, so I check it myself? This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). Attach the log file as you reply.
Please also check these helpful articles below:
Wi-Fi 6 vs. Wi-Fi 6E/7: Understanding 6 GHz Band Support Differences
How to Enable 6 GHz Band Using Intel® Wi-Fi 6E or Wi-Fi 7 Products
I will wait for your reply.
JeanetteC.
huahua
Thank you for your prompt reply
Same system, if I use intel driver 23.30.0.6, it can work on Wi-Fi7, But if the driver is 23.110.0.5, it will change to Wi-Fi6.
Attached the system configuration per your requirement:
JeanetteC_Intel
Hello huahua,
Please confirm the following details below:
1) Is this the correct system/PC you have, https://www.bee-link.com/products/beelink-eqi12?\ ?
2) May I know from what download link did you get the driver version 23.30.0.6?
3) Is the Intel® Wi-Fi 7 BE200 an upgrade component?
JeanetteC.
huahua
Yes,PC is EQi12 12650H Intel(R) Core(TM) i7-12650H
About a year ago, I confirmed that the Intel® Wi-Fi 7 BE200 is compatible with Wi-Fi 7 technology, that is why I kept an older driver version internally
Yes, Wi-Fi 7 BE200 is an upgrade component. it is ax101 by default
JeanetteC_Intel
Hello huahua,
I hope these helps.
JeanetteC.
二狗
JeanetteC_Intel
Hello huahua,
I am sharing the following articles for your reference:
 I will now proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
huahua
I was trying to enable wi-fi7, not 6G. it is also Regulatory  related?
