Wireless
8718 Discussions
Wi-Fi 6E (6GHz) Not Working on Ubuntu 22.04.5 and 24.04.1 with Intel AX211/BE200
LunarDrifter
Hello!
I am experiencing an issue where Wi-Fi 6E (6GHz) is not working on Ubuntu 22.04.5 (kernel 6.8.0-40-generic) and Ubuntu 24.04.1 (kernel 6.8.0-51-generic). However, it does work on Ubuntu 22.04.1 (kernel 5.15.0-43-generic).
I have tested this with both Intel AX211 and Intel BE200, and the problem persists with both cards.
System & Configuration Details:
  • Operating System: Ubuntu 22.04.1 / 22.04.5 / 24.04.1
  • Kernel Versions Tested:
    • Wi-Fi 6E NOT Working: 6.8.0-40-generic (Ubuntu 22.04.5), 6.8.0-51-generic (Ubuntu 24.04.1)
    • Wi-Fi 6E Working: 5.15.0-43-generic (Ubuntu 22.04.1)
  • Wi-Fi Cards Tested: Intel AX211, Intel BE200
  • Country/Regulatory Domain: Poland (PL)
Troubleshooting Steps Taken:
  1. Regulatory domain: Manually set to Poland (iw reg set PL), but no effect.
  2. Kernel Downgrade: Switching back to 5.15.0-43-generic restores 6GHz functionality.
  3. Firmware Updates: Ensured linux-firmware package is up-to-date.
  4. Checked NetworkManager and iwlwifi Module: No configuration changes helped.
Questions:
  1. Is this a known issue with recent Linux kernels (6.8.x) and Intel Wi-Fi 6E cards?
  2. Are there any additional settings required to enable 6GHz operation on newer kernels?
  3. Could this be a regulatory domain issue, or has support been changed in the iwlwifi driver?
Any guidance or potential fixes would be greatly appreciated. Thanks in advance!
Command Outputs:
Below are the outputs of relevant commands for debugging. Commands were used on Ubuntu 24.04.1 on which Wi-Fi 6E does not work. It seems that 6GHz frequencies are completely disabled despite being present in older kernel versions.
$ iw dev
phy#0
	Unnamed/non-netdev interface
		wdev 0x3c
		addr xx:xx:xx:xx:xx:xx
		type P2P-device
	Interface wlp0s20f3
		ifindex 8
		wdev 0x1
		type managed
		txpower 22.00 dBm
		multicast TXQ:
			qsz-byt	qsz-pkt	flows	drops	marks	overlmt	hashcoltx-bytes	tx-packets
			0	0	0	0	0	0	0	00
$ iw list
Wiphy phy0
	wiphy index: 0
	max # scan SSIDs: 20
	max scan IEs length: 365 bytes
	max # sched scan SSIDs: 20
	max # match sets: 8
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Device supports RSN-IBSS.
	Device supports AP-side u-APSD.
	Device supports T-DLS.
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP-128 (00-0f-ac:4)
		* GCMP-128 (00-0f-ac:8)
		* GCMP-256 (00-0f-ac:9)
		* CMAC (00-0f-ac:6)
		* GMAC-128 (00-0f-ac:11)
		* GMAC-256 (00-0f-ac:12)
	Available Antennas: TX 0x3 RX 0x3
	Configured Antennas: TX 0x3 RX 0x3
	Supported interface modes:
		 * IBSS
		 * managed
		 * AP
		 * AP/VLAN
		 * monitor
		 * P2P-client
		 * P2P-GO
		 * P2P-device
	Band 1:
		Capabilities: 0x19ef
			RX LDPC
			HT20/HT40
			SM Power Save disabled
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			Max AMSDU length: 7935 bytes
			DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: 4 usec (0x05)
		HT Max RX data rate: 300 Mbps
		HT TX/RX MCS rate indexes supported: 0-15
		HE Iftypes: managed
			HE MAC Capabilities (0x78019a30abc0):
				+HTC HE Supported
				Trigger Frame MAC Padding Duration: 2
				Multi-TID Aggregation Support: 7
				Broadcast TWT
				32-bit BA Bitmap
				OM Control
				Maximum A-MPDU Length Exponent: 3
				RX Control Frame to MultiBSS
				A-MSDU in A-MPDU
				Multi-TID Aggregation TX: 7
				UL 2x996-Tone RU
			HE PHY Capabilities: (0x023f4e09fd098c160ffc01):
				HE40/2.4GHz
				Punctured Preamble RX: 15
				Device Class: 1
				LDPC Coding in Payload
				NDP with 4x HE-LTF and 3.2us GI
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				Full Bandwidth UL MU-MIMO
				DCM Max Constellation: 1
				DCM Max Constellation Rx: 1
				SU Beamformee
				Beamformee STS <= 80Mhz: 7
				Beamformee STS > 80Mhz: 7
				Sounding Dimensions <= 80Mhz: 1
				Sounding Dimensions > 80Mhz: 1
				Triggered SU Beamforming Feedback
				Triggered MU Beamforming Feedback
				PPE Threshold Present
				Power Boost Factor ar
				HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
				Max NC: 2
				HE ER SU PPDU 4x HE-LTF 0.8us GI
				20MHz in 40MHz HE PPDU 2.4GHz
				20MHz in 160/80+80MHz HE PPDU
				80MHz in 160/80+80MHz HE PPDU
				TX 1024-QAM
				RX 1024-QAM
				RX Full BW SU Using HE MU PPDU with Compression SIGB
				RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
			HE RX MCS and NSS set <= 80 MHz
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				3 streams: not supported
				4 streams: not supported
				5 streams: not supported
				6 streams: not supported
				7 streams: not supported
				8 streams: not supported
			HE TX MCS and NSS set <= 80 MHz
				1 streams: MCS 0-11
				2 streams: MCS 0-11
			PPE Threshold 0x61 0x1c 0xc7 0x71
		HE Iftypes: AP
			HE MAC Capabilities (0x78011a100000):
				+HTC HE Supported
				Broadcast TWT
				OM Control
			HE PHY Capabilities: (0x02200e090009800401c400):
				HE40/2.4GHz
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				TX 1024-QAM
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
		Bitrates (non-HT):
			* 1.0 Mbps
			* 2.0 Mbps (short preamble supported)
			* 5.5 Mbps (short preamble supported)
			* 11.0 Mbps (short preamble supported)
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 2412.0 MHz [1] (22.0 dBm)
			* 2417.0 MHz [2] (22.0 dBm)
			* 2422.0 MHz [3] (22.0 dBm)
			* 2427.0 MHz [4] (22.0 dBm)
			* 2432.0 MHz [5] (22.0 dBm)
			* 2437.0 MHz [6] (22.0 dBm)
			* 2442.0 MHz [7] (22.0 dBm)
			* 2447.0 MHz [8] (22.0 dBm)
			* 2452.0 MHz [9] (22.0 dBm)
			* 2457.0 MHz [10] (22.0 dBm)
			* 2462.0 MHz [11] (22.0 dBm)
			* 2467.0 MHz [12] (22.0 dBm)
			* 2472.0 MHz [13] (22.0 dBm)
			* 2484.0 MHz [14] (disabled)
	Band 2:
			RX LDPC
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			DSSS/CCK HT40
		VHT Capabilities (0x039071f6):
			Max MPDU length: 11454
			Supported Channel Width: 160 MHz
			RX LDPC
			short GI (80 MHz)
			short GI (160/80+80 MHz)
			TX STBC
			SU Beamformee
			MU Beamformee
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
		VHT RX highest supported: 0 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
		VHT TX highest supported: 0 Mbps
		VHT extended NSS: supported
		HE Iftypes: managed
			HE MAC Capabilities (0x78018a30abc0):
				+HTC HE Supported
				Broadcast TWT
				32-bit BA Bitmap
				OM Control
				Maximum A-MPDU Length Exponent: 1
				A-MSDU in A-MPDU
				UL 2x996-Tone RU
			HE PHY Capabilities: (0x0c3f4e09fd098c160ffc01):
				HE40/HE80/5GHz
				HE160/5GHz
				Device Class: 1
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				SU Beamformee
				Max NC: 2
				TX 1024-QAM
				RX 1024-QAM
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
			HE RX MCS and NSS set 160 MHz
				1 streams: MCS 0-11
				2 streams: MCS 0-11
			HE TX MCS and NSS set 160 MHz
				1 streams: MCS 0-11
				2 streams: MCS 0-11
		HE Iftypes: AP
			HE MAC Capabilities (0x78010a100000):
				+HTC HE Supported
				Broadcast TWT
				OM Control
			HE PHY Capabilities: (0x0c200e090009800401c400):
				HE40/HE80/5GHz
				HE160/5GHz
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				TX 1024-QAM
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5180.0 MHz [36] (22.0 dBm) (no IR)
			* 5200.0 MHz [40] (22.0 dBm) (no IR)
			* 5220.0 MHz [44] (22.0 dBm) (no IR)
			* 5240.0 MHz [48] (22.0 dBm) (no IR)
			* 5260.0 MHz [52] (22.0 dBm) (no IR, radar detection)
			* 5280.0 MHz [56] (22.0 dBm) (no IR, radar detection)
			* 5300.0 MHz [60] (22.0 dBm) (no IR, radar detection)
			* 5320.0 MHz [64] (22.0 dBm) (no IR, radar detection)
			* 5340.0 MHz [68] (disabled)
			* 5360.0 MHz [72] (disabled)
			* 5380.0 MHz [76] (disabled)
			* 5400.0 MHz [80] (disabled)
			* 5420.0 MHz [84] (disabled)
			* 5440.0 MHz [88] (disabled)
			* 5460.0 MHz [92] (disabled)
			* 5480.0 MHz [96] (disabled)
			* 5500.0 MHz [100] (22.0 dBm) (no IR, radar detection)
			* 5520.0 MHz [104] (22.0 dBm) (no IR, radar detection)
			* 5540.0 MHz [108] (22.0 dBm) (no IR, radar detection)
			* 5560.0 MHz [112] (22.0 dBm) (no IR, radar detection)
			* 5580.0 MHz [116] (22.0 dBm) (no IR, radar detection)
			* 5600.0 MHz [120] (22.0 dBm) (no IR, radar detection)
			* 5620.0 MHz [124] (22.0 dBm) (no IR, radar detection)
			* 5640.0 MHz [128] (22.0 dBm) (no IR, radar detection)
			* 5660.0 MHz [132] (22.0 dBm) (no IR, radar detection)
			* 5680.0 MHz [136] (22.0 dBm) (no IR, radar detection)
			* 5700.0 MHz [140] (22.0 dBm) (no IR, radar detection)
			* 5720.0 MHz [144] (disabled)
			* 5745.0 MHz [149] (22.0 dBm)
			* 5765.0 MHz [153] (22.0 dBm)
			* 5785.0 MHz [157] (22.0 dBm)
			* 5805.0 MHz [161] (22.0 dBm)
			* 5825.0 MHz [165] (22.0 dBm)
			* 5845.0 MHz [169] (22.0 dBm)
			* 5865.0 MHz [173] (22.0 dBm)
			* 5885.0 MHz [177] (disabled)
			* 5905.0 MHz [181] (disabled)
	Band 4:
		HE Iftypes: managed
				+HTC HE Supported
				Broadcast TWT
				32-bit BA Bitmap
				OM Control
				A-MSDU in A-MPDU
				UL 2x996-Tone RU
				HE40/HE80/5GHz
				HE160/5GHz
				Device Class: 1
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				SU Beamformee
				Max NC: 2
				TX 1024-QAM
				RX 1024-QAM
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
		HE Iftypes: AP
				+HTC HE Supported
				Broadcast TWT
				OM Control
				HE40/HE80/5GHz
				HE160/5GHz
				STBC Tx <= 80MHz
				STBC Rx <= 80MHz
				TX 1024-QAM
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
				1 streams: MCS 0-11
				2 streams: MCS 0-11
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5955.0 MHz [1] (disabled)
			* 5975.0 MHz [5] (disabled)
			* 5995.0 MHz [9] (disabled)
			* 6015.0 MHz [13] (disabled)
			* 6035.0 MHz [17] (disabled)
			* 6055.0 MHz [21] (disabled)
			* 6075.0 MHz [25] (disabled)
			* 6095.0 MHz [29] (disabled)
			* 6115.0 MHz [33] (disabled)
			* 6135.0 MHz [37] (disabled)
			* 6155.0 MHz [41] (disabled)
			* 6175.0 MHz [45] (disabled)
			* 6195.0 MHz [49] (disabled)
			* 6215.0 MHz [53] (disabled)
			* 6235.0 MHz [57] (disabled)
			* 6255.0 MHz [61] (disabled)
			* 6275.0 MHz [65] (disabled)
			* 6295.0 MHz [69] (disabled)
			* 6315.0 MHz [73] (disabled)
			* 6335.0 MHz [77] (disabled)
			* 6355.0 MHz [81] (disabled)
			* 6375.0 MHz [85] (disabled)
			* 6395.0 MHz [89] (disabled)
			* 6415.0 MHz [93] (disabled)
			* 6435.0 MHz [97] (disabled)
			* 6455.0 MHz [101] (disabled)
			* 6475.0 MHz [105] (disabled)
			* 6495.0 MHz [109] (disabled)
			* 6515.0 MHz [113] (disabled)
			* 6535.0 MHz [117] (disabled)
			* 6555.0 MHz [121] (disabled)
			* 6575.0 MHz [125] (disabled)
			* 6595.0 MHz [129] (disabled)
			* 6615.0 MHz [133] (disabled)
			* 6635.0 MHz [137] (disabled)
			* 6655.0 MHz [141] (disabled)
			* 6675.0 MHz [145] (disabled)
			* 6695.0 MHz [149] (disabled)
			* 6715.0 MHz [153] (disabled)
			* 6735.0 MHz [157] (disabled)
			* 6755.0 MHz [161] (disabled)
			* 6775.0 MHz [165] (disabled)
			* 6795.0 MHz [169] (disabled)
			* 6815.0 MHz [173] (disabled)
			* 6835.0 MHz [177] (disabled)
			* 6855.0 MHz [181] (disabled)
			* 6875.0 MHz [185] (disabled)
			* 6895.0 MHz [189] (disabled)
			* 6915.0 MHz [193] (disabled)
			* 6935.0 MHz [197] (disabled)
			* 6955.0 MHz [201] (disabled)
			* 6975.0 MHz [205] (disabled)
			* 6995.0 MHz [209] (disabled)
			* 7015.0 MHz [213] (disabled)
			* 7035.0 MHz [217] (disabled)
			* 7055.0 MHz [221] (disabled)
			* 7075.0 MHz [225] (disabled)
			* 7095.0 MHz [229] (disabled)
			* 7115.0 MHz [233] (disabled)
	Supported commands:
		 * new_interface
		 * set_interface
		 * new_key
		 * start_ap
		 * new_station
		 * new_mpath
		 * set_mesh_config
		 * set_bss
		 * authenticate
		 * associate
		 * deauthenticate
		 * disassociate
		 * join_ibss
		 * join_mesh
		 * remain_on_channel
		 * set_tx_bitrate_mask
		 * frame
		 * frame_wait_cancel
		 * set_wiphy_netns
		 * set_channel
		 * tdls_mgmt
		 * tdls_oper
		 * start_sched_scan
		 * probe_client
		 * set_noack_map
		 * register_beacons
		 * start_p2p_device
		 * set_mcast_rate
		 * connect
		 * disconnect
		 * channel_switch
		 * set_qos_map
		 * add_tx_ts
		 * set_multicast_to_unicast
	WoWLAN support:
		 * wake up on disconnect
		 * wake up on magic packet
		 * wake up on pattern match, up to 20 patterns of 16-128 bytes,
		   maximum packet offset 0 bytes
		 * can do GTK rekeying
		 * wake up on GTK rekey failure
		 * wake up on EAP identity request
		 * wake up on 4-way handshake
		 * wake up on rfkill release
		 * wake up on network detection, up to 8 match sets
	software interface modes (can always be added):
		 * AP/VLAN
		 * monitor
	valid interface combinations:
		 * #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
		   total <= 3, #channels <= 2
	HT Capability overrides:
		 * MCS: ff ff ff ff ff ff ff ff ff ff
		 * maximum A-MSDU length
		 * supported channel width
		 * short GI for 40 MHz
		 * max A-MPDU length exponent
		 * min MPDU start spacing
	Device supports TX status socket option.
	Device supports HT-IBSS.
	Device supports SAE with AUTHENTICATE command
	Device supports low priority scan.
	Device supports scan flush.
	Device supports per-vif TX power setting
	P2P GO supports CT window setting
	P2P GO supports opportunistic powersave setting
	Driver supports full state transitions for AP/GO clients
	Driver supports a userspace MPM
	Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
	Device adds DS IE to probe requests
	Device can update TPC Report IE
	Device supports static SMPS
	Device supports dynamic SMPS
	Device supports WMM-AC admission (TSPECs)
	Device supports configuring vdev MAC-addr on create.
	Device supports randomizing MAC-addr in scans.
	Device supports randomizing MAC-addr in sched scans.
	Device supports randomizing MAC-addr in net-detect scans.
	max # scan plans: 2
	max scan plan interval: 65535
	max scan plan iterations: 254
	Supported TX frame types:
		 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
	Supported RX frame types:
		 * IBSS: 0x40 0xb0 0xc0 0xd0
		 * managed: 0x40 0xb0 0xd0
		 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * mesh point: 0xb0 0xc0 0xd0
		 * P2P-client: 0x40 0xd0
		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * P2P-device: 0x40 0xd0
	Supported extended features:
		* [ VHT_IBSS ]: VHT-IBSS
		* [ RRM ]: RRM
		* [ MU_MIMO_AIR_SNIFFER ]: MU-MIMO sniffer
		* [ SCAN_START_TIME ]: scan start timestamp
		* [ BSS_PARENT_TSF ]: BSS last beacon/probe TSF
		* [ BEACON_RATE_LEGACY ]: legacy beacon rate setting
		* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
		* [ FILS_MAX_CHANNEL_TIME ]: FILS max channel attribute override with dwell time
		* [ ACCEPT_BCAST_PROBE_RESP ]: accepts broadcast probe response
		* [ OCE_PROBE_REQ_HIGH_TX_RATE ]: probe request TX at high rate (at least 5.5Mbps)
		* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
		* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
		* [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
		* [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
		* [ PROTECTED_TWT ]: protected Target Wake Time (TWT) support
		* [ DEL_IBSS_STA ]: deletion of IBSS station support
		* [ BEACON_PROTECTION_CLIENT ]: beacon prot. for clients support
		* [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
		* [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
		* [ POWERED_ADDR_CHANGE ]: can change MAC address while up
global
country 00: DFS-UNSET
	(2402 - 2472 @ 40), (6, 20), (N/A)
	(2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
	(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
	(5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
	(5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
	(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
	(5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
	(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country PL: DFS-UNSET
	(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
	(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
	(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
	(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5490 - 5510 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5510 - 5530 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5530 - 5550 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5550 - 5570 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5570 - 5590 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5590 - 5610 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5610 - 5630 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
	(5630 - 5650 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
	(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
	(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
	(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
	(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
	(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, NO-320MHZ
	(5835 - 5855 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ
	(5855 - 5875 @ 20), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ
JeanetteC_Intel
Hello LunarDrifter,
Please give me time to check on this internally and will post an update once available.
JeanetteC.
JeanetteC_Intel
Hello LunarDrifter,
Good day!
Please reach out to your OS distributor as we don't have limitations with specific kernel versions and is always suggested using the latest stable version.
I'll proceed in closing this thread now.
Sincerely,
JeanetteC.
