Wireless
9023 Discussions
Wi-Fi Card Upgrade
Dobro
Upgrade Killer (R) Wi-Fi 6E AX 1675 160MHZ Wi-Fi card to a Giga Plus BE200 NGW Wi-Fi 7 Wireless Card
3Fees
Intel Killer (R) Wi-Fi 6E AX 1675 160MHZ Wi-Fi card uses System Interface Type:PCIe, BT(USB)
Intel Wi-Fi 7 BE200 320MHZ Wi-Fi card uses System Interface Type M.2: PCIe, USB
Intel BE200 wifi 7 ONLY works on intel. It is not compatible with AMD.
Intel BE200 Wi-Fi card only works with 600 and 700 series Intel chipsets.
You'll need a Wi-Fi 7 Router to run BE200 @320MHZ.
If you have the requirements all signs point to okay.
        Cheers
        3Fees
n_scott_pearson
No, that's not a true characterization. This is:
  • The Intel Killer WiFi 6E AX1675 (x|w) card uses standard M.2 Type E interface.
  • The Intel Killer WiFi 6E AX1675 (i/s) card uses special M.2 Type E interface with CNVio2 support. This is what ties it to the 600 & 700 Series Intel chipsets. The card only includes the PHY portion; the MAC portion is built into the chipset.
  • The Intel WiFi 7 BE200 card uses standard M.2 Type E interface.
  • It's true that the Intel WiFi 7 BE200 card does not work in AMD-based systems.
  • It's true that you'll need a WiFi 7 Router before the Intel WiFi 7 BE200 card can operate at the full 320MHz.
  • It's definitely NOT true that the Intel WiFi 7 BE200 card only works with 600 and 700 Series Intel chipsets. I have one installed in an older system with 8 Series chipset and Core i7-4770 processor and it runs just great (albeit only tested with WiFi 6 router).
So, to the OP's question, whether he can upgrade to the Intel WiFi 7 BE200 card depends upon what type of Intel Killer WiFi 6E AX1675 card he has.
  • If it's an Intel Killer WiFi 6E AX1675 (x|w) card, an Intel WiFi 7 BE200 card should work just fine.
  • If it's an Intel Killer WiFi 6E AX1675 (i/s) card, then it's not guaranteed to work. It depends upon how the M.2 Type E interface with CNVio2 support is laid out. In most cases, it will work, but I have read of outliers.
Just saying,
