Wireless
8700 Discussions
Only getting 300Mbps when have 1Gig internet on PC only
Pirate_tat87
Here is the information:
Internet Provider: Optimum
System: PC
Connection: Wi-Fi
Network Card: Intel(R) Wi-Fi 6 AX201 160MHz
Speed Test Results: Using Optimum's Wi-Fi Speed test site: Download 261Mbps
Trouble Shooting Steps Performed
Step 1: I first wanted to make sure that I had the latest network drivers in my system, so when I first checked the driver version, I had the information was
Driver Date: 01-21-2024 - Version: 23.30.0.6
Step 2: Thinking that I am receiving the lower speeds due to an outdated driver, I decided to update my Intel Wi-Fi Driver
https://www.intel.com/content/www/u...fi-drivers-for-windows-10-and-windows-11.html
After the install and reboot of the computer, Verified Driver Date: 09-4-2024 - Driver Version: 23.80.1.3
When performing a speed test again still only getting download speeds of 300Mbps
The browsers not if that matters that I tested the internet speed with is (Microsoft Edge, Firefox, Opera Gx, Opera, Google Chrome) all sites giving the same speed test results
https://www.optimum.com/internet/speed-test / I have also tested using https://speedtest.net
This is when I decided to check my other devices, they all seem to be getting correct download speeds for my laptop and mobile device.
System 2: Laptop
Network Card: Intel (R) Wi-Fi 6 AX201 160MHz
Driver Date: 10-18-2022
Version: 22.180.0.4
Connection Type: Wireless
Speed Test Results: Using Optimum's Wifi Speedtest site: Download 863.2Mbps
System 3: Samsung Galaxy S24
Connection: Wireless
Speed Test Results: Using Optimum's Wifi Speedtest site: Download 993.7Mbps
So I'm a bit at a loss on what the next trouble shooting steps should be or where I should look, Any help would be greatly appreciated.
*note* I am unable to test my PC using an ethernet connection as I do not as of current have a long enough Ethernet cable to test with
Also not sure if this information is needed,
Microsoft Windows [Version 10.0.22631.4391]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Vince
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 4:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe 2.5GbE Family Controller
Physical Address. . . . . . . . . : 2C-F0-5D-9F-A3-EB
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
Physical Address. . . . . . . . . : C8-58-C0-00-8D-82
Wireless LAN adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #6
Physical Address. . . . . . . . . : CA-58-C0-00-8D-81
Wireless LAN adapter Wi-Fi 2:
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX201 160MHz
Physical Address. . . . . . . . . : C8-58-C0-00-8D-81
IPv6 Address. . . . . . . . . . . : 2600:4809:2031:3400:e85f:c6ac:d833:4571(Preferred)
Temporary IPv6 Address. . . . . . : 2600:4809:2031:3400:40d0:72e:514b:4b96(Preferred)
Link-local IPv6 Address . . . . . : fe80::7421:f202:ce80:f074%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.147(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, November 5, 2024 10:04:58 AM
Lease Expires . . . . . . . . . . : Tuesday, November 5, 2024 11:35:01 AM
Default Gateway . . . . . . . . . : fe80::964e:5bff:fe5a:5663%8
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 264788160
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2D-BD-C5-8C-C8-5A-CF-0C-0C-25
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
