Wireless
8789 Discussions
WiFi 6 AX210 not working after ubuntu mate update, bluetooth does
ralph_
Dear community,
yesterday i turned on my new P14s AMD gen2, with an Intel WiFi 6 AX 210 non Vpro installed, and realised it isn't working, while bluetooth is.
I tried several different work arounds i found on the internet (askubuntu.com, itsfoss.com, ..) but nothing worked.
Then i did a full reinstall of the linux distro including installing all relevant applications for me, again after an update WiFi not working, while bluetooth is.
So today again a new clean ubunut mate 20.04.2 LTS installation.
And again after sudo apt update and sudo apt upgrade --> WiFi not working, while bluetooth is.
And again before the update&upgrade it did work, as the 2 times before.
No other application has been installed the last time, just a fresh and clean ubuntu mate (fresh iso download) ..
System is working with dual boot with win 10, there everything works fine.
Any other suggestions?
Oh yeah, kernel is 5.11. for shure.
Thanks in common.
ralph_
David_G_Intel
Hello ralph_
Thank you for posting on the Intel️® communities. Make sure you're running the correct firmware and latest drivers for this card:
If it works on Windows 10* this confirms its not a defective wireless card but If the issue persists, please provide the Intel® System Support Utility (Intel® SSU) results
David G
ralph_
Thanks for the support.
I also opened a thread at askubuntu and they where able to help me, i will post the solution in my previous post.
ralph_
negative, it worked fine at the beginning and always with windows.
It was a softwarebug.
ralph_
The solution, with the help of the askubuntu community, can be seen here:
https://askubuntu.com/questions/1360175/intel-wifi-5-ax210-wifi-not-working-after-update
David_G_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
David G
David_G_Intel
Last thing before closing this thread, if the problem reoccurs we recommend checking with the distro and OEM respectively as this is a new system.
David G
