Wireless
8626 Discussions
WiFi Direct support on 6 GHz channels
Gr3g
Does the WiFi driver for AX2xx card for Windows (and/or Linux) support WiFi Direct over 6 GHz channels?
If not, is there any other Intel WiFi card that would support that type of connection?
Has anyone successfully connected Windows equipped with AX2xx card with another device using WiFi-Direct that operate on 6 GHz channel?
Note: My device is not a Miracast device, so I'm interested in general Direct connection.
Greg
RandyT_Intel
Hello Gr3g,
WiFi Direct Support over 6 GHz Channels:
  • The Intel AX200 and AX201 cards support WiFi 6 (802.11ax) but only on the 2.4 GHz and 5 GHz bands. They do not support WiFi Direct over 6 GHz channels as they are not WiFi 6E cards.
  • For WiFi Direct over 6 GHz channels, you would need a WiFi 6E card, such as the Intel AX210 or AX211
  • The Intel AX210 and AX211 are WiFi 6E cards that support the 6 GHz band. These cards would be suitable for your needs if you require WiFi Direct over 6 GHz channels
There are reports of users experiencing issues with WiFi Direct connections using AX200 cards, particularly with Miracast devices. However, these issues are often related to specific configurations or software updates rather than the hardware itself. For general WiFi Direct connections, it is essential to ensure that both devices support the same WiFi Direct standards and that the drivers are up to date.
You can check this article: Wi-Fi 6 vs. Wi-Fi 6E/7: Understanding 6 GHz Band Support Differences
Randy T.
RandyT_Intel
Hello Gr3g,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
Gr3g
Hold on
Thanks for the information you provided. Do you have any evidence that someone has successfully connected from Windows using AX21x card to another device over WiFi Direct 6GHz? Or even maybe using two Windows PCs with the same AX21x cards?
Is it that the only way to achieve Direct over 6GHz channels is to use Miracast? I would be more interested to utlize WiFi Direct, but not Miracast.
Greg
RandyT_Intel
Hello Gr3g,
I would like to share this article for additional information: How to Enable 6 GHz Band Using Intel® Wi-Fi 6E or Wi-Fi 7 Products
Randy T.
