Wireless
8653 Discussions
WiFi Setting and Driver disappear automatically Intel® Dual Band Wireless-AC 3160
MKama4
WiFi setting is completely disappear automatically after restarting or shutdown
and it back again after many shutdown and run pc or many restating
i trying all solution of Other Theards but the problem is stilling
when i open device manger and chose show hidden driver the driver of WiFi is existing but hidden
i post the image below
recently i used wifi usb and this problem dosent appear for this device but intel always disappear and appear again automatically au usual
Hello MahmoudKamal
Thank you for posting in the Intel® community.
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
MKama4
Thanks For Your Replaying
Yes I delete all driver and Make clean installation for wireless driver
and Upgrade Driver To Latest version
and i Think It may be problem with Last version so i downgrade again but the problem is stilling exist
i try all solution but No of this is solve it
and re install Windows also
Hello MahmoudKamal
Thank you for the information.
Given all the test and troubleshooting perform on the behavior, a clean installation of the wireless driver different versions and a clean installation of the Operating System (OS) I would recommend contacting DELL™ the Original Equipment Manufacturer (OEM) for possible hardware issues.
Dell support:
https://www.dell.com/support/contents/us/en/04/category/contact-information?~ck=mn https://www.dell.com/support/contents/us/en/04/category/contact-information?~ck=mn
Hope this helps.
Leonardo C.
MKama4
I Made It Before
clean installation for Wireless driver and also Os
and Now When I trying To Install Other Version It give Me That Message
Hello MahmoudKamal
  • Have you tried to roll back the wireless driver on the device manager? See the steps below.
  • Have you tried the OEM driver? See download link below.
  • If you are having problems to install a previous wireless driver I would recommend uninstalling the current driver on the system to complete the new installation.
  • Roll back drivers steps:
  • Right click on the Windows logo.
  • Select device manager.
  • Browse for the Intel® Dual Band Wireless-AC 3160.
  • Right on the wireless adapter, select properties.
  • Go to the driver tab.
  • Select roll back driver.
If the behavior persists it could be related to a hardware problem, if this is the case I would recommend contacting the OEM for warranty options.
Hope this helps.
Leonardo C.
