Wireless
8515 Discussions
WiFi driver No config found for PCI dev 7af0/0244 on Linux
WaCe
kernel version
6.1.0-25-amd64
# dmesg | grep iwlwifi
[    2.597503] Intel(R) Wireless WiFi driver for Linux
[    2.597683] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    2.601668] perf uncore: Cannot find matched IMC device.
[    2.601716] perf uncore: Cannot find matched IMC device.
[    2.601762] perf uncore: Cannot find matched IMC device.
[    2.601808] perf uncore: Cannot find matched IMC device.
[    2.604016] iwlwifi: No config found for PCI dev 7af0/0244, rev=0x430, rfid=0x10c000
[    2.604047] iwlwifi: probe of 0000:00:14.3 failed with error -22
# lspci -kvnn | sed -n '/Network/,/^$/ p'
00:14.3 Network controller [0280]: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:7af0] (rev 11)
       DeviceName: Onboard - Ethernet
       Subsystem: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:0244]
       Flags: fast devsel, IRQ 18
       Memory at 9341c000 (64-bit, non-prefetchable) [size=16K]
       Capabilities: [c8] Power Management version 3
       Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
       Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
       Capabilities: [80] MSI-X: Enable- Count=16 Masked-
       Capabilities: [100] Latency Tolerance Reporting
       Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
       Kernel modules: iwlwifi
Bluetooth is working normal.
have download latest linux-firmware-20240811  and copy intel folder to  and iwlwifi-* /lib/firmware/intel/lib/firmware/
WaCe
I check the hardware name is Inte WiFi 6 AX101.
