Wireless
8622 Discussions
Wifi 6E AX210 crashing computer
LupinneSpeed
Computer crashes every few days, and I narrowed it down to the wifi card, it is saying a driver in it is missing or corrupted but wont install new software for any given reason. This crashing only started again after putting the wifi card back in as well to further narrow it down, and I've tried a lot of different things to fix it but nothing works otherwise. I am running on Win11, and it says my drivers are up to date and also reinstalled my GPU drivers fresh (someone recommended to do so).
- I also put a .Zip containing a .evtx of the error code
n_scott_pearson
I suggest that you do a clean install of the Wireless and Bluetooth drivers. Here is the process:
  1. If you haven't already, download - but do not install just yet - the desired Bluetooth and Wireless driver packages for your adapter. Here are the current links for downloading these drivers: Wireless: https://www.intel.com/content/www/us/en/download/19351 and Bluetooth: https://www.intel.com/content/www/us/en/download/18649
  2. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Wi-Fi 6e AX210 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an intel driver associated with it. If neither is the case, go to Step 10.
  7. Right click on the entry for Intel Wi-Fi 6e AX210 and uninstall it, choosing to (checkmark) Delete the driver software for this device.
  8. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  9. Go to Step 5.
  10. (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. Ensure you have enabled cleaning of System Files. I recommend that you then checkmark all categories offered, even if no files currently in this category (so it leaves it set up for next invocation).
  11. (Optional but recommended) Clear each of your browsers' cache.
  12. Install the downloaded Bluetooth driver package (my rule: always install Bluetooth first).
  13. Install the downloaded Wireless driver package.
  14. Manually shutdown and reboot your computer.
  15. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  16. Test.
Hope this helps,
Spaece
it worked for me thank you so much !
