Wireless
9029 Discussions
Wifi Driver Not found
subrat
I have installed ubuntu 20.04
and i have intel wifi card & unable to use wifi
current kernel version: 5.15-101-generic
VonM_Intel
Hi, subrat.
Thank you for posting in our Community.
You're encountering challenges with your Intel Wi-Fi card on Ubuntu 20.04, which could be due to a variety of factors such as outdated or corrupted drivers, recent OS updates, hardware not being recognized, misconfiguration, or software conflicts.
To clarify, are you indicating that your system is not detecting the Wi-Fi driver? Any extra details you can provide will be useful in troubleshooting the problem. While you've mentioned your operating system and kernel version, more information about your hardware and software setup would be helpful. Running an SSU report would allow me to examine crucial details like the OS build number, the Wi-Fi driver version, and any system-level errors.
Von M.
VonM_Intel
Hi, subrat.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
subrat
Can you please help me with the steps to run Intel SSU on ubuntu linux
LeonWaksman
VonM_Intel
Hi, subrat.
You may follow these steps:
  1. Download the Intel® System Support Utility for the Linux* operating system and save the ssu.tar.gz file to your system.
  2. Extract the ssu.sh file from ssu.tar.gz and save to your system.
  3. To run the ssu.sh script from a Linux terminal, Open Applications->Accessories->Terminal.
  4. From the current directory, navigate to the current folder where the ssu.sh file resides. For example, if you saved the ssu.sh file to a folder called SSU File, the command would be cd SSU File.
  5. Run the ssu.sh file using this command: ./ssu.sh <parameter=0|1> where 0 = off and 1 = enabled.
  6. Use the parameter definitions included in the readme to determine which parameter to use.
    Note If no parameter is specified and only ./ssu.sh is run, it captures all system information with the exception of 3rd party logs that must be specified.
    • If no output file is specified, the Intel System Support Utility writes the output to the <systemname>.txt file.
  7. You can view or open the output file in most text editors. However, view the file in a word processing software, such as WordPad*, for better formatted viewing. In addition, the Intel® System Support Utility for Windows can open the output file, which provides you with the capability of viewing the Linux information in an easy-to-view user interface.
Additionally, you can refer to this article/link: "Assistance Guide for the Intel® System Support Utility" and "Intel® System Support Utility for the Linux* Operating System," which provided instructions on how to run the Intel SSU.
Von M.
VonM_Intel
Hi, subrat.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
