Wireless
8624 Discussions
Wifi card AX200 not detected
RyanHmz
I have recently buy a new wifi card for my PC cause the current one is old and have somes problems but this new card isn't detected on my PC with Windows 10.
It's this : Cudy WE3000 Ax3000 Carte WiFi 6 PCIe, 2402Mbps + 574Mbps, AX200, OFDMA, Bluetooth 5.0/4.2/4.0, Windows 10
https://www.amazon.fr/dp/B082NZYDDM?ref=ppx_yo2ov_dt_b_fed_asin_title
I don't see it in the Device Manager, even when I try to see the invisible device.
I have install and uninstall this driver many times but it doesn't change https://www.intel.com/content/www/us/en/products/sku/204836/intel-wifi-6e-ax210-gig/downloads.html
I tried to put the card in the PCIe slot 1, 16 where my old Wifi card is detected but it doesn't work, .
I read on forums that the card may not work with certain motherboards maybe somone know more about that. Mine is Gigabyte GA-AB350-Gaming 3 Carte mère AMD B350 Socket AM4 https://www.amazon.fr/dp/B06XMYM95G?ref=ppx_yo2ov_dt_b_fed_asin_title
I don't know if someone have an idea so I'm waiting for your response, thank you.
n_scott_pearson
PCIe WiFi card carrier devices such as this have problems if they are plugged into PCIe x4/x8/x16 slots. You should have it plugged into a PCIe x1 slot. Your motherboard only has one of these slots; I hope it is available.
Hope this helps,
RyanHmz
I had tried in the two PCIe x1 (where my old card works) but it didn't work.
BUT in less than 24h my pc crashed 5-6 times and now the wifi card appears in the device manager (one time I get the error code 0xc0000225).
I don't know if I may be happy but I hope that my problem is solve (but not for a new one), thank you for your help
And in conclusion I don't know how I have solve it X)
