Wireless
8546 Discussions
Wifi chip not picking up networks
gutgyk123
I just built my first PC, and im setting up windows. My wifi card is the Intel(R) Wi-Fi 6E AX210 160MHz. when i go into the wifi setting it says the wifi is enabled, and the chip is working fine, but it says no Wi-Fi networks found. I've tried running trouble shooter, and doing all the resets and stuff, none of it works. i have the drivers installed to, those are working fine. this is the product listing in case you need more info on the product: itself https://www.amazon.com/gp/product/B08MJLPZPL/ref=ox_sc_act_image_1?smid=A1P510M40JY8CO&psc=1 if you can help that would be great, My discord is gutgyk123, dm me if you think you can help (i strongly hate talking through forums)
ShunMnzed
hello...
Have you checked if your Wi-Fi router is broadcasting a network that other devices can detect, to ensure it's not an issue with the router itself?
You can reset your network settings as a first step, To do that, In Windows, you can try resetting your network settings. Go to "Network & Internet" settings > "Status" > "Network reset" and follow the prompts. This will reset all network adapters and settings to their default.
regards,
Tyler Shun
