Wireless
8545 Discussions
Wifi driver ax201 not working
Aıdan
I have an asus fx506li computer that has windows 11 installed. For the past year or so the ax201 wifi driver installed on it has periodically stopped working. Recently it has stopped working much more frequently and I have manually installed newer versions of the driver which have also had the same problem.
Every time it fails the event that shows up says “device not started (netwtw 10)”.
Aıdan
Hello, after not finding an answer here or on several other tech support forums I decided to get a new WiFi card which seems to have fixed the issue
3Fees
What does device manager say in Network adapters- Advanced- Wireless mode- value ?
Cheers
3Fees
Aıdan
In 802. 11a/b/g wireless mode it says dual band 802.11a/b/g
In 802.11n/ac/ax wireless mode it says 802.11ax
3Fees
Should be set to one or the other, the top one works for me. 802.11 a/b/g
Cheers
3Fees
Aıdan
Thanks for the suggestion, however it still isn’t working.
AlfredoS_Intel
Hi Aidan,
I have noticed that your still have an unresolved concern. Kindly allow me to ask the following questions, so I can determine the best recommendations for your concern:
1. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* for instructions.
Awaiting your response.
Alfred S
Aıdan
