Will intel(R) dual band wireless-AC 7260 support full version of My wifi Dashboard ? I downloaded My WiFi Dashboard_15.6.0_64.msi for my 64 bit Windows 7 OS. But only lite version is getting installed. Any work around, to install full version ?
Hello Sivaraman,
Please note the driver is available for download for other Wireless adapters. The one you have is not listed under the valid products for the download so you may get unexpected behavior during the installation or usage of the software.
Here you can see the compatible products with the software:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22695&lang=eng&ProdId=3551 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22695&lang=eng&ProdId=3551
This was the driver I downloaded from the link below. But still it is installing only the 'LITE' version, & not the 'FULL' version.
Does that mean 'Intel(R) dual band wireless-AC 7260' supports only 'LITE'version, & not FULL version?
Hello Sivaraman,
We have a tool called Intel® PROSet that pretty much has all the functions and features of the WiFi Dashboard. Is there any specific feature you are trying to use or looking for?
Kevin M
I want to convert my laptop to a wifi hotspot. This is my primary requirement.
How to do it ? Mine is DELL Latitude E7440
Sivaraman H
Cell number: 9845228625
I downloaded all the software & driver from https://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=3622&DwnldID=24217 Intel® Download Center Wireless_17.1.0_s64.exe & Wireless_17.1.0_Ds64.exe
How to configure for wifi hotspot ?
The PROSet features are these:
http://www.intel.com/support/wireless/wlan/sb/CS-030415.htm http://www.intel.com/support/wireless/wlan/sb/CS-030415.htm
You can try setting up a Hosted Network on Windows. Here you have important links:
http://msdn.microsoft.com/en-us/library/windows/desktop/dd815252(v=vs.85).aspx http://msdn.microsoft.com/en-us/library/windows/desktop/dd815252(v=vs.85).aspx
Here is another:
http://msdn.microsoft.com/en-us/library/windows/desktop/dd815243(v=vs.85).aspx http://msdn.microsoft.com/en-us/library/windows/desktop/dd815243(v=vs.85).aspx
Kevin M
Hi Sivaraman,
You can also try setting a Hotspot with PROSet. Here you have the instructions:
http://www.intel.com/support/wireless/wlan/sb/CS-034116.htm http://www.intel.com/support/wireless/wlan/sb/CS-034116.htm
Kevin M
The step 3 in the link you provided is showing just the screenshot given below:- (Using OS Windows 7 Professional 64 Bit)
What to do ?
Hi Sivaraman,
Please find the below link which gives some information of why only the lite version is getting installed:
http://www.intel.com/support/notebook/sb/CS-033660.htm http://www.intel.com/support/notebook/sb/CS-033660.htm
So now as you have already mentioned that you have installed the 15.6.0 version of Proset drivers, I would request that you can try installing the below drivers and check if you are facing the same issue:
http://https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23992 http://https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23992
Kunal
