Wireless
8873 Discussions
Will this AX200 Wireless module compatible with my hardware?
AClar26
Will it work with any mainboard that support M.2 slot key A/E, even on a non Intel Processor/Mobo Chipset? Do I need any special requirements for this wireless module or almost any RF and antenna that design for M.2 wireless card will work just like Intel AC 9260? Thank you.
https://ark.intel.com/content/www/us/en/ark/products/189347/intel-wi-fi-6-ax200.html
David_V_Intel
Hello AClar26,
Thank you for posting on the Intel ® communities.
In this case, what you are trying to do is a wireless integration. You need to check and understand the regulatory information in the link below:
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html
Also, you need to check with, either your system manufacturer, or, if your system is a custom-built, you must contact the motherboard manufacturer and check with them.
I hope this helps.
David V
A Contingent Worker at Intel
