Wireless
9023 Discussions
Windows 10 and 7260N problems
CWong15
For heaven's sakes.
The intel driver 18.12.1 keeps installing drivers for 7265N for my 7260N card in Windows 10.
CWong15
Even though the drivers install successfully, in the network settings in control panel does not detect any network adapters.
ASouz7
Hello, 神之未來
Windows*10 supports the Intel® Dual Band Wireless-N 7265 with its inbox drivers version: (17.15.0.5).
What do you mean when you say that " the intel driver 18.12.1 keeps installing drivers for 7265N for my 7260N card in Windows 10."
Could you give us a better picture of your issue?
CWong15
Sorry that my English is not good.
My wireless card is Wireless-N 7260, it worked fine with 18.12.0 drivers, but when I install the 18.12.1 drivers, it's somehow mistaking my 7260 as the model 7265, where in device manager it changed from Wireless-N 7260 to Wireless-N 7265, wrong drivers for the wrong card, that is why my network adapter is missing in control panel and the system cannot detect the device but still in device manager it says the device is running.
Now my computer have no way to connect to the internet without ethernet.
ASouz7
神之未來,
Intel recommends that you always use latest drivers offered by your computer manufacturer first. There are two version of this N adapter, the Intel® Dual Band Wireless-N 7260 and the Intel® Wireless-N 7260 (this one being single-banded) which one do you have? Please make sure you installed the right driver for the right adapter. If you are not too sure which one do you have, please contact your computer manufacturer for further information: http://www.intel.com/support/oems.htm Computer Manufacturer Support
For the Intel® Dual Band Wireless-N 7260 you may try the following: https://downloadcenter.intel.com/download/25196/Intel-PROSet-Wireless-Software-for-Windows-10 Intel® PROSet/Wireless Software for Windows® 10 - Please make sure to observe your operating system architecture if it is 32 or 64 bit. Click on this link: http://www.intel.com/content/www/us/en/wireless-products/dual-band-wireless-n-7260-brief.html Intel® Dual Band Wireless-N 7260: Product Brief for the more information.
For the Intel® Wireless-N 7260 you may try the following: https://downloadcenter.intel.com/download/25196/Intel-PROSet-Wireless-Software-for-Windows-10 Intel® PROSet/Wireless Software for Windows® 10 - It is also important that you follow the same procedure informed above for the dual band version. Click on the link: http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/wireless-n-7260-bluetooth-brief.pdf Intel® Wireless-N 7260: Product Brief
CWong15
Mine is dual-band wireless-n 7260, and I did download the 64 bit win10 version, Sony claims they used intel drivers and it should work perfectly, but apparantly, I'm only have been successfully install the driver only after a clean install of windows 10, upgrades somehow just installs drivers for other hardware.
ASouz7
Hello 神之未來
Please try the following:
1. Remove this hidden folder:C:\Users\YOUR_PROFILE_NAME\AppData\Roaming\Intel
2. Remove drivers, Intel® PROSet/Wireless Software, temp files and hidden folders. Then reboot computer. Let Windows* install driver.
temp files:
1.On the keyboard, press Win + R to open Run dialogue box.
2.On search box, type %temp% and press OK.
3.This will open one of Windows temporary files folder. Select all files and delete them.
To select all files, click on any file within folder and press ctrl + A.
If any files are been used by computer, then you might get a message that says "File in use" or "Folder in use". Click on Skip to continue.Once all files are removed, please proceed with the installation.Let us know if this worked for you.
ACiuf3
I am using Windows 10 64bit on HP 840 G2 laptop.
The last driver 18.30.0 included in 19.1.0.4 HP package give many Windows panic.
Using the 18.12.0 drivers all problems are solved in the last 3 weeks.
It is not very easy find this drive version but I can share with you.
