Wireless
8661 Discussions
Windows 8 crashes when I try to install Intel® Centrino® Wireless-N 135 driver
JRuss7
My wifi has been acting up so I went to Intel website to see if my drivers needed to be updated. Sure enough, it says "Newer Intel® PROSet/Wireless WiFi Connection Utility Available 16.1.1 is available. Problem is, when I saved the file to my desktop and then try to run it, Windows 8 crashes.
So how exactly do I run/install this new driver? Any suggestions?
thanks
Jose_H_Intel1
You may try uninstalling the old version first from Programs and Features and Device Manager. Then, delete these folders before running the installer again:
If the above suggestion does not help, please indicate if this is a clean Windows* 8 installation or an upgrade over existing Windows* 7.
