Wireless
8515 Discussions
Wireless 6200AGN maximum speed?
Hello.
I have a 120 MB Internet service, but my 6200AGN doesn't provide a speed higher than 60 mbps, even if I am near the modem.
Besides, the 6200AGN speed is always oscillating between 58mbps and 130mbps. It's not supposed that this wireless card reach 300mbps?
I've done all the configurations suggested by Intel to improve the card performance, but nothing changed.
Could you help me please?
Thanks!!!
the recommendation on this case is to make sure that you have the correct settings to work with the "N" protocol, for that I suggest you to visit the following links so you can see the recommended settings:
What are the recommended settings for 802.11n connectivity?
http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=%28wireless+n+recommendations%29 http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=%28wireless+n+recommendations%29
Data rate will not exceed 54 Mbps when WEP or TKIP encryption is configured
http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm
Possible interference by other wireless devices may impact 802.11n performance
http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm
Another recommendation is to contact the router manufacturer and confirm that your current settings are the recommended setting for best performance and also confirm if they have a new firmware available for it.
