Wireless
8506 Discussions
Wireless AC 9560 160MHz - Chromecast network issue
Zenon3
When playing movie on Google Chrome
I start casting to Chromecast
All OK as Google Chrome has focus
When minimise Google Chrome
after about 30 seconds sound is becoming corrupted
Subsequent to maximise Google Chrome sound is still corrupted
Pausing and restarting movie fixes sound issue
On request available video which illustrates the issue (483 MB)
Computer
Device          Aspire 3 A315-58-58PP
Processor       11th Gen Intel(R) Core(TM) i5-1135G7
Installed RAM   20.0 GB
Wireless LAN adapter          Intel Wireless-AC 9560 160MHz
Wireless LAN driver date      06/18/2023
Wireless LAN driver Version   22.240.0.6
Edition Windows 11 Home
Version 22H2    All updates up to 15-Aug-2023 installed
OS build        22621.1928
Google Chrome
Version 114.0.5735.199 (Official Build) (64-bit)
Fibre router
TP-LINK AX3000 Archer AX50
Chromecast
Chromecast with Google TV 4K
TV Set Samsung-UA65KS8000
Attemted remedies – 1-8 NOT succefull
1. Uninstall and reinstall driver
2. Reset the laptop BIOS to factory defaults using the "tiny pin hole"
3. Factory Reset Windows 11
4. Modify the Wireless LAN driver settings
Set 1 Set 2
802.11 a/b/g Wireless Mode Dual-band 802.11a/b/g or 802.11a/b/g Dual-band 802.11a/b/g or 802.11a/b/g
802.11n/ac Wireless Mode 802.11ac or VHT Mode 802.11ac or VHT Mode
ARP offload for WoWLAN Disabled Disabled
Channel Width for 2.4GHz Auto (Access Point determines width) Auto (Access Point determines width)
Channel Width for 5GHz Auto (Access Point determines width) Auto (Access Point determines width)
Fat Channel Intolerant Disabled (default) Disabled (default)
GTK rekeying for WoWLAN Enabled (default) Enabled (default)
MIMO Power Save Mode Auto No SMPS
Mixed Mode Protection RTS/CTS Enabled (default) CTS-to-self Enabled
NS offload for WoWLAN Enabled (default) Disabled
Packet Coalescing Enabled (default) Enabled (default)
Preferred Band Prefer 5 GHz band Prefer 5 GHz band
Roaming Aggressiveness Medium Medium
Sleep on WoWLAN Disconnect Disabled (default) Disabled (default)
Throughput Booster Disabled Disabled
Transmit Power Highest (Default) Highest (Default)
U-APSD support Disabled (default) Disabled (default)
Wake on Magic Packet Disabled Disabled
Wake on Pattern Match Disabled Disabled
5. Elevating Chrome.exe using line command:
   wmic process where name="chrome.exe" CALL setpriority "Realtime"
6. Reset All Network Settings using:
   Settings > Network & internet > Advanced network settings > Network reset
7. Generated Wi-Fi Reports for
   - sound OK
   - sound corrupted
   There are NO noteworthy differences
8. Executed the following line commands as Administrator:
       netsh int ip reset
       netsh advfirewall reset
       netsh winsock reset
       ipconfig /flushdns
       ipconfig /release
       ipconfig /renew
    After about 2 minutes – not like before after 30 seconds - sound is
    becoming corrupted
9. To eliminate Wi-Fi: direct cable connection between laptop RJ45 to fibre
    router
    Result: sound OK.
10. Downgrade Windows 11 to Windows 10 and using Wi-Fi
    Result: sound OK
Conclusion
It looks for me the driver for Intel Wireless-AC 9560 160MHz adapter
has some issue with Windows 11.
Jocelyn_Intel
Hello, @Zenon3
Thank you for your time.
After checking the reports and the troubleshooting that has been done, we recommend you to check this issue with your System Manufacturer as it does not seem wireless-related.
We advise you to check the sound drivers, that is out of our scope. This thread will no longer be monitored due to the reason above, thank you for your understanding.
Jocelyn M.
Jocelyn_Intel
Hello, @Zenon3
Thank you for posting on the Intel® communities. I will gladly assist you here.
Please, answer these questions to have a better perspective of this issue:
  1. Is the Intel® Wireless-AC 9560 the pre-installed wi-fi card in your laptop or is it an integration (upgrade/ not the original card)?
  2. Was it working fine before?
  3. Does this issue happen with another network or router?
Jocelyn M.
Zenon3
Hi Jocelyn,
Thank you for reply.
  1. The Intel Wireless-AC 9560 is the pre-installed wi-fi card in my laptop
  2. It was not working from the beginning
  3. I did not have chance to check if this issue happen with another network or router
Kind regards
Zenon3
Jocelyn_Intel
Hello, @Zenon3
Thank you for the information provided.
Note #1: Make sure to check you have all the Windows updates before doing the driver installation. Also, make sure to do this step disconnected from the internet (wi-fi or wired connection) when you are uninstalling the driver software since Microsoft updates drivers automatically and prevents doing the clean installation successfully.
Note #2: We recommend checking with your System Manufacturer and using the driver software provided by them to avoid potential installation incompatibilities. Intel supplies generic versions of Wireless Drivers for general purposes. Computer manufacturers might have changed the features, incorporated customizations, or made other changes to the Wireless driver software or software packaging.
Jocelyn M.
Zenon3
Hi Jocelyn,
I followed your advice. Please find the results.3
  1. 13. Perform a Clean Installation of Wireless Drivers
    All Windows 11 updates intalled
    Disconnect from the internet
    In “Device Manager” removed device “Wireless-AC 9560 160MHz”
       with option “Atempt to remove driver for this device” selected
    Reboot laptop
    Result:
       Device “Wireless-AC 9560 160MHz” automatically installed with
       Driver provider:  Microsoft
       Driver date:      17/01/2021
       Driver version:   22.01.5
       Driver signer:    Microsoft
       Connected to Wi-Fi
       Test sound: corrupted
  1. 14. Update driver using System Manufacturer's driver
    Wireless LAN_Intel_22.120.1.9_W11x64_(INT9462 and INT9560)
       Connected to Wi-Fi
  1. 15. Update driver using latest wireless driver
    “WiFi-22.240.0-Driver64-Win10-Win11”
       Connected to Wi-Fi
  1. 16. Trying fibre router “DrayTek Vigor 2860ac”
       Latest wireless driver
       Connected to Wi-Fi
Jocelyn_Intel
Hello, @Zenon3
Thank you for your reply and the information provided.
In this case, please provide us with an Intel SSU report to have more information about your laptop and investigate this issue:
Intel® System Support Utility for Windows.
Note: Make sure to mark the box that says "everything" before pressing the Scan button. After that, click on "Next>" and select "Save" and then, attach the .txt file.
Jocelyn M.
Jocelyn_Intel
Hello, @Zenon3
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Zenon3
Hi Jocelyn,
Please find updated summary and attached file Chromecast network issue Intel SSU Report.txt
The issue still exist.
Kind regards
Zenon3
Computer
OS build 22621.1928
Google Chrome
Fibre router
Chromecast
Attemted remedies – all NOT succefull except 11 & 12
Set 1 Set 2
5. Setting laptop and Chromecast to use 2.4 GHz
6. Setting laptop and Chromecast to use 5 GHz
7. Elevating Chrome.exe using line command:
8. Reset All Network Settings using:
9. Generated Wi-Fi Reports for
- sound OK
- sound corrupted
10. Executed the following line commands as Administrator:
netsh int ip reset
netsh winsock reset
ipconfig /flushdns
ipconfig /release
ipconfig /renew
becoming corrupted
11. To eliminate Wi-Fi: direct cable connection between laptop RJ45 to fibre
router
Result: sound OK.
12. Downgrade Windows 11 to Windows 10 and using Wi-Fi
Result: sound OK
Reboot laptop
Result:
Connected to Wi-Fi
Connected to Wi-Fi
Connected to Wi-Fi
Connected to Wi-Fi
17. Created report using Intel System Support Utility for Windows.
Box "everything" checked before pressing the Scan button.
File "Chromecast network issue Intel SSU Report" created
Conclusion
Jocelyn_Intel
Hello, @Zenon3
I will proceed to do some research on this. As soon as I have updates on this, I will let you know here.
Thank you for your time in advance.
Jocelyn M.
Jocelyn_Intel
Hello, @Zenon3
Jocelyn M.
Zenon3
Hi Jocelyn,
Many thanks for help.
I check again  direct cable connection between laptop RJ45 to fibre
router to eliminate Wi-Fi.
The issue exist so clearly this not Wi-Fi.
I am very sorry for troble
Kind regards
Zenon3
