Wireless
9036 Discussions
Wireless Bluetooth
dubiletto
Wireless Bluetooth® version 22.240.0 This is what I currently have.
PC sleep mode and startup after sleep mode, the Intel Bluetooth hardware installed in my PC no longer works, it is no longer recognizable. I have to restart my entire PC for everything to work. The Bluetooth tells the PC not found after going to sleep. The taskbar icon is not showing for Bluetooth settings, and I can't get it to work. The solution found is to restart the PC completely.
dubiletto
I went to the wrong forum, I started again in the wireless section.
Jose_Intel
Hello @dubiletto
Thank you for posting on the Intel️® communities.
We understand you opened a new thread for the issue with the Bluetooth, so you will be helped there. This thread will no longer be monitored. Thank you for understanding.
Jose B.
