Wireless
8955 Discussions
Wireless Network Adapter Automatically Disabled When Booting with Ethernet Cable Connected
Kaway-Stone
When I turn on my laptop (ASUS B1509CVA) with an Ethernet cable plugged in and enter Windows 11, the wireless network adapter (Intel Wi-Fi 6E AX211 160MHz) is automatically disabled. In Device Manager, I can see that the wireless adapter is in a disabled state, and if I manually enable it, it works for about 1-2 seconds before automatically disabling again. As a result, I cannot use the Wi-Fi function.
However, if I start the laptop without the Ethernet cable plugged in, everything works fine. In other words, the Ethernet cable should only be plugged in after the system has fully booted to the desktop—this prevents the wireless adapter from being inexplicably disabled, ensuring that both wired and wireless networks can function normally.
Mike_Intel
Hello Kaway-Stone,
  1. When did you start having this issue?
  2. What was the last change made on the system before the issue started?
  3. Did you manually install this Intel AX211 on your system or this is embedded?
  4. What are the troubleshooting steps that you tried so far?
Michael L.
Mike_Intel
Hello Kaway-Stone,
Michael L.
Mike_Intel
Hello Kaway-Stone,
I am sending another follow up on the information that I requested.
Michael L.
