Wireless
Annonces
8576 Discussions
Wireless/Networking Driver Problems
sgeneris
Débutant
28 176 Visites
Dell Latitude E7450 laptop running Windows10 64bit.
Unable to get a response from Dell.
I ran into problems with some software not seeing my Internet connection even though it works fine.
Tried to update the Dell driver for Intel wireless 7265 and got the attached fatal error and log.
Tried to install ISDA and got the attached error and log.
Attached is the SSU report.
Would appreciate your help.
0 Compliments
56 Réponses
n_scott_pearson
Super utilisateur
10 640 Visites
What? Dell support didn't respond? SHOCKING! (Well... not. No surprise there. Perfectly normal)...
I would suggest that you try manually uninstalling and then reinstalling the driver package. You can manually download the packages from here:
It is recommended that you uninstall these as a pair and installed them as a pair (Bluetooth first).
Hope this helps,
0 Compliments
sgeneris
Débutant
10 633 Visites
Thanks for responding.
Yes, that would have been logical.
However, because there are several problems I do not know if the driver is the problem. If it's not,at least the wifi now works, but if I uninstall and cannot reinstall I will lose the wifi and I don't have another computer.
0 Compliments
sgeneris
Débutant
10 632 Visites
Incidentally, the link you referred me has the ISDA but if fails installing too.
0 Compliments
sgeneris
Débutant
10 622 Visites
Oops -- the drivers you linked to require a later Windows 10 version than I have.
0 Compliments
AndrewG_Intel
Employé
10 614 Visites
Hello @sgeneris
Regarding these issues to install or update the driver for Intel® Dual Band Wireless-AC 7265, after checking the Intel® System Support Utility (Intel SSU) report, we noticed that your system is running Windows* 10 Pro Build 10586 (version 1511) which is an old version of Windows® from 2015.
Microsoft* was moving to a new Universal Drivers architecture starting with Windows® 10 October 2018 Update which represented a shift in Intel® drivers and the release of DCH drivers (Declarative Componentized Hardware supported apps). Windows DCH Drivers are driver packages that will install and run on Universal Windows Platform (UWP) based editions of Windows® 10.
All Wi-Fi driver versions after 20.20.0.x (for 8000/9000 adapters) and 19.51.9.x (for 7265/3165/3168 adapters) are DCH compliant Drivers. The latest driver versions we have available in our download center for the Intel® Dual Band Wireless-AC 7265 are 19.51.31.1 and 19.51.30.
In this case, we suspect that the installation issue could be related to incompatibility between the operating system (OS) version and the driver versions. Having said that, are you able to update Windows® to one of the latest versions (e.g. 2004 or 20H2) and then try to install the driver again?
For instructions on how to update Windows*, we recommend contacting Microsoft support directly for proper instructions:
Download Windows 10 October 2020 Update (20H2)* >> https://www.microsoft.com/en-us/software-download/windows10
Microsoft Support* >> https://support.microsoft.com/
Once the OS has been updated, you may try to install the drivers again following the instructions in this link:
Clean Installation of Wireless Drivers >> https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless.html
Here is the driver download link, version 19.51.31.1 (package: 22.0.0) https://downloadcenter.intel.com/download/29902/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters?product=83635
We hope this helps.
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
0 Compliments
sgeneris
Débutant
10 609 Visites
Thank you for responding.
Yes, I am using the oldest solid version of W10 ON PURPOSE -- to avoid the catastrophe that MS created after that -- won't touch any newer version.
However:
  • I have 2 identical laptops with identical sware; both have the Dell driver v. 19!
  • There's networking problems with one, but not the other: Dell's SupportAssist fails to install, and Command Update fails checking for new drivers claiming there is no Internet connection; and IDSA fails to install.
Apparently having something to do with not recognizing/seeing the Internet connection.
Any ideas?
0 Compliments
sgeneris
Débutant
10 605 Visites
I'm attaching the error and log of the ISDA failure to install. Can you tell me why?
0 Compliments
n_scott_pearson
Super utilisateur
10 598 Visites
The problem with your approach is that Intel does not support all versions of Windows 10. They support only the current (i.e. 20H2/2009) and three previous (i.e. 20H1/2004, 1909 and 1904). Problems -- not just with installation -- are going to occur.
Sorry,
0 Compliments
sgeneris
Débutant
10 595 Visites
Yes, I understand that, but I have no problem with Intel. If you check out my reply to Andrew, I hoped that people here would figure out the source of the problems that may well be due to Dell, but I am not technical enough to figure it out myself how to fix -- failure to recognize the Internet connection.
0 Compliments
n_scott_pearson
Super utilisateur
10 588 Visites
I believe that the right answer is for you to go back to the drivers that were provided by Dell. Presumably, when the laptop shipped, the solution was working. I suggest that you use my clean install process, but this time use the Wireless and Bluetooth drivers from Dell, not the latest from intel.
Here's the process, just to be complete:
  1. If you haven't already, download - but do not install just yet - the latest Bluetooth and WiFi drivers for your adapter from the Dell site.
  2. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  3. From Apps & Features, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to step 6.
  4. Uninstall each instance present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer.
  6. In Device Manager, check Network Adapters for an entry for Intel Dual Band Wireless-AC 7265. If none, go to Step 9.
  7. Right click on the entry for Intel Dual Band Wireless-AC 7265 and uninstall it, choosing to (checkmark) Delete the driver software for this device.
  8. Go to Step 5.
  9. (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. I recommend that you checkmark all categories offered, even if no files currently (so it leaves it set up for next invocation).
  10. (Optional but recommended) Clear each of your browsers' cache.
  11. Install the Bluetooth driver package (rule: always do Bluetooth first).
  12. Install the Wireless driver package.
  13. Manually shutdown and reboot your computer.
  14. Enable Internet access.
  15. Test.
Hope this helps,
0 Compliments
sgeneris
Débutant
10 583 Visites
Thanks. But no Intel drivers were ever installed -- the only installed drivers are v.19 FROM THE DELL SITE. So there is nothing to "go back to". I thought of trying the Intel drivers to see if they solve the problem, but they would not install.
Bear in mind that Dell SupportAssist or Command Update check the tag# of the system and tell you whether there are new drivers available FOR THAT SPECIFIC laptop, based on whatever the original OS it came with. It will not recommend drivers incompatible with that OS. The v.19 drivers were so recommended, installed and have worked. However, at some point Command Update started claiming there is no Internet connection and it cannot check for new drivers. It may have nothing to do with the drivers -- the question is what could cause the utility to not see the Internet connection -- that's why I provided the logs, that somebody technical could figure it out.
0 Compliments
n_scott_pearson
Super utilisateur
10 580 Visites
Ah, I see what you are saying. I wonder if this is what is displayed if the server is not responding or not currently available?
0 Compliments
sgeneris
Débutant
10 576 Visites
I am sure that is not the case because, as I said, this happens only with one of two identical laptops that run identical software -- they are clones -- the other connects fine. Something must have happened on it hidden from me and I am trying to find out what that could be.
0 Compliments
n_scott_pearson
Super utilisateur
10 563 Visites
Sorry, I am out of (obvious) possibilities.
BTW, never think of them as being clones. They *are* different. The timing of and order that things get installed in - especially via Windows Update - can vary and, while the packages may all be the same, the software payloads overall will differ. Only through regular cloning of the system drive could you attempt to keep them close - and even then...
0 Compliments
sgeneris
Débutant
10 554 Visites
Yes, I am aware of that -- that is why I provided the logs such that maybe a rech person might figure out the difference between the 2 systems that causes the problem. I dk how to read and interpret those logs.
I guess not, but thanks for your help.
0 Compliments
n_scott_pearson
Super utilisateur
10 548 Visites
Your driver-txt.log file is telling me that the uninstall details file for the previous install of the driver package - which lists the minute install operations performed during the original install - is missing. It thus doesn't know how to uninstall it and hence why it says Fatal Error.
Now, knowing what is going wrong and doing anything about it are two different things. You can try to manually uninstall (via Apps and Features or Device Manager uninstall) the wireless package(s) and see if that gets you going again. If it doesn't, then Intel Customer Support will need to see if there is a special uninstaller that can clean up (from) this state.
0 Compliments
sgeneris
Débutant
10 545 Visites
Does it tell you exactly WHICH driver it is -- Intel or Dell -- and what version?
I never had Intel drivers installed, so it must be Dell and I did not try to uninstall the Dell drivers -- so I can't figure it out.
0 Compliments
sgeneris
Débutant
10 519 Visites
Dell has 2 drivers -- BT and Wifi -- that are more recent than the ones listed
in Device Manager.
Re wifi the log file explains the fatal error. So:
1. Where do I find Apps and Features?
2. How do I contact Intel Customer support to ask about an uninstall/cleanup?
Re BT: I ran the install of the newer BT, but when I then check ,DM still lists the old version. I then used the Update Driver in DM and now it lists neither the old, nor the new, but a third version:
Old: 20.100.3.1/1/8/2019
Newer: 21.80.0.3/20 Jul 2020
DM: 20.100.6.4 10/3/2019
Any idea what's going on?
0 Compliments
sgeneris
Débutant
10 517 Visites
Re wifi driver: Even weirder:
Device Manager lists 19.51.18.1  12/31/2018
But Revo Uninstaller program says 20.120.1.
How can this be?
0 Compliments
n_scott_pearson
Super utilisateur
10 236 Visites
It's amazing how often this question gets asked!
Device Manager is telling you the driver version number while Apps & Programs (and 3rd-party apps like Revo Uninstaller) are telling you the package version number. Why are they different? Because the packages contain separate drivers for each of the Wireless modules that is supported by that package. There will be cases where a package is released but only a single driver has actually been updated. In this case, the package and only the one driver will have had their version numbers incremented (the other drivers will retain their previous version numbers).
Plain as mud?
0 Compliments
Répondre
