Wireless
8661 Discussions
Wirless Problem in ubuntu22.04
EdwardJackson
Please help me solve it.
Edward Jackson.
sudo dmesg | grep iwlwifi
[ 2.871502] iwlwifi: probe of 0000:00:14.3 failed with error -110
[ 1136.599633] iwlwifi 0000:00:14.3: Detected crf-id 0x1300504, cnv-id 0x80930 wfpm id 0x80005b30
[ 1136.599637] iwlwifi 0000:00:14.3: PCI dev 7740/0274, rev=0x460, rfid=0x10a100
[ 1136.599690] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-86.ucode failed with error -2
[ 1136.599702] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-85.ucode failed with error -2
[ 1136.599711] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-84.ucode failed with error -2
[ 1136.599720] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-83.ucode failed with error -2
[ 1136.599729] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-82.ucode failed with error -2
[ 1136.599738] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-81.ucode failed with error -2
[ 1136.599747] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-hr-b0-80.ucode failed with error -2
[ 1136.599748] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 1136.599749] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-bz-a0-hr-b0-80
[ 1136.599750] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-bz-a0-hr-b0-86
Mike_Intel
Hello EdwardJackson,
  1. Can you further explain the exact issue?
  2. What is the model of your wireless controller since I cannot see it in the SSU logs.
  3. Did you manually install the wireless card or is it embedded on the system?
  4. Was it working fine before?
  5. What was the mast change made in the system before the issue started?
Michael L.
EdwardJackson
Hello Mike_Intel,
Thank you for replying to my question.
I have installed a dual-boot system on my Redmi Book Pro 14 2025 laptop (the laptop came with Windows 11 pre-installed, and I added Ubuntu as a secondary OS). I’ve tried multiple Ubuntu versions — 22.04, 20.04, and even 24.04 — but none of them are able to connect to Wi-Fi.
My original wireless card was an Intel AX203, and I even tried replacing it with an AX211, but both resulted in the same error:
Both wireless cards work perfectly fine under Windows, but when I switch to Ubuntu, no Wi-Fi interface appears. I’ve tried many solutions found online, but none of them worked, which has been very frustrating.
Eventually, I gave up on dual-booting and switched to running Ubuntu in a VMware virtual machine under Windows. This setup meets my basic needs for now, but I still hope to be able to use Ubuntu directly on my laptop in the future.
If you’re able to help me resolve this issue, I would be extremely grateful!
Best wishes,
Edward Jackson
Mike_Intel
Thank you for the update.
For customers who upgraded their wireless card, we have a Regulatory information to follow since you need to consider some details. Kindly read the Regulatory information below for more details:
Regulatory Information Regarding Wireless Hardware Installation or...
Have you tried contacting the manufacturer of the laptop for further assistance?
Michael L.
Mike_Intel
Michael L.
Mike_Intel
I am sending another follow up and hoping that you are now talking to the manufacturer of the system.
Michael L.
