Wireless
8780 Discussions
ax210 6GHz band
jevans22
Will I need an antenna upgrade? How can my existing antenna utilize the 6GHz frequencies?
David_G_Intel
Hello jevans22
We need more information from your computer, please share with us the Intel® System Support Utility (Intel® SSU) results
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
David_G_Intel
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
David G.
Intel Customer Support Technician
David_G_Intel
David G.
