Wireless
8667 Discussions
can get wireless to conect windows 7 tried FN+F8 and F12 any clues please
hi anyone need some help can't connect to internet via wireless have tried FN+F8 and F12
Hello Leshia,
Thank you for your question.
Usually the FN+(F8,F10,F11, or even F12) combinations can sometimes be used on laptops to enable or disable the wireless radio.
However, not all connectivity issues directly relate to your wireless adapter being turned off. In order to better assist you, we'd like to have some information:
- What is the brand and model of your computer?
- Which operating sytem are you using? (ie. Windows* 7 Home Basic, 32 or 64-bit)
- Could you please provide us with a more detailed description of the issue? For example, are you able to see wireless networks, but fail to connect? Or maybe you can't detect any wireless networks altogether?
- Where you able to connect before?
- Have you recently made any changes to your system?
We look forward to hearing back from you.
Kind regards,
Carlos A.
Hello Carlos
thanks for reply computer is a
Toshiba satellite P850 PSPKBA-04P00U
serial nu 4C063218K
windows 7 home Prem OA 2009 unsure if 32 or 64 bit
unable to see any wireless network computer worked on wireless until few days ago
regards
Leshia
Hello Leshia,
From the specifications page for your laptop we're unable to determine which wireless adapter comes preinstalled on your system. We can see that it will be either an Intel® adapter, Atheros*, or Realtek*.
To find out which is installed, you'll need to open the Control Panel > Device Manager > Network Adapters
If you see any devices named "Intel(R) [Centrino(R), Wireless, WiFi, or Dual Band Wireless] ...":
- http://support.toshiba.com/support/driversResults?freeText=4C063218K&osId=31 Toshiba* Satellite* P850 (PSPKBA-04P00U) Software & Drivers > Filter by: Network.
1. Download Intel® Wireless Drivers, save it to a known location.
2. In Control Panel > Device Manager > Network Adapters, right click on the Intel® {WIRELESS ADAPTER MODEL} and Uninstall it. Make sure you mark the option to "Delete the driver software for this device".
3. Remove temporary files: Press the Windows* Key + R to open the run box. Type Cleanmgr.exe. Press OK. Select the main drive, usually "C:\". Check Temporary Files and uncheck everything else. Press OK.
4. Install the latest Intel® Wireless driver.
If you do not see an Intel® Wireless Adapter, but you do see another brand adapter (Atheros*, or Realtek*), you will need to contact your http://www.intel.com/content/www/us/en/support/topics/OEMs.html computer manufacturer's support team for further assistance.
Note: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
We hope this helps.
Carlos A.
Thank you Carlos
I have found out it is a Realtek program
but thankyou very much for your support
you have been very accommodating
Regards Leshia
Hello Leshia,
You're welcome. I'm glad we were able to help you regardless.
Carlos A.
