Wireless
8874 Discussions
how be200 enable mlo feature?
BobOne
system:ubuntu 24.10
lshw:
*-network
description: Ethernet interface
product: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:07:00.0
logical name: wlp7s0f0
version: 1a
serial: xx:xx:xx:xx:xx:xx
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.11.0-9-generic firmware=92.67ce4588.0 gl-c0-fm-c0-92.uc latency=0 link=yes multicast=yes
resources: irq:16 memory:8a900000-8a903fff
wpa_supplicant use 2.11 and CONFIG_IEEE80211BE=y
BobOne
root@ubuntu2410:/home/software# iw dev
phy#0
Unnamed/non-netdev interface
wdev 0x2
addr c8:xx:xx:xx:57:5a
type P2P-device
Interface wlp7s0f0
ifindex 7
wdev 0x1
addr c8:xx:xa:xx:57:59
ssid xxxxmlo
type managed
channel 44 (5220 MHz), width: 80 MHz, center1: 5210 MHz
txpower 22.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
I  can't find the link1 .....    link2.........
what shoul i do if i want enable mlo?
