Wireless
8515 Discussions
how to set the wireless mode of soft access point for the network card of intel 5300
I had set the wireless mode of my network-adapter to 802.11a in device manager, but when i start the soft access point (as input the command of netsh wlan start hostednetwork), i can only see a wireless network of mode 802.11g.
Is there any correct method to set the wireless mode of soft access point?
What's more, is it able to set the channel or Qos(WMM), beacon interval of this card?
There is a Ad Hoc Qos Mode in the advance property of the wifi card in which you can enable the WMM.
this setting should be available somewhere in your soft access point software you use.
you might want to refer to this website: http://www.intel.com/support/wireless/wlan/sb/CS-025393.htm
