Wireless
8661 Discussions
intel ax200 bluetooth - device power failure
syonnne
im using hp elitebook 1030 x360 g4 with an intel ax200 hardware bluetooth driver version 23.150
it keeps on failing, i kept on re installing the drivers (23.150) multiple times,
it works for 1-2 days and it falls apart again and i need to re install the drivers again
this is the message from device manager (device has yellow exclamation mark)
This device cannot start. (Code 10)
STATUS_DEVICE_POWER_FAILURE
is there any older driver versions that work well? or is there any other fixes regarding this issue?
or maybe newer driver update? or maybe its not bluetooth related
thanks
Mike_Intel
Hello syonnne,
  1. Was it working fine before?
  2. What was the last change made in the system before the issue started?
  3. How did you update the driver?
  4. For me to review the hardware and the driver installed, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
Mike_Intel
Hello syonnne,
Michael L.
Mike_Intel
Hello syonnne,
I am sending another follow up on the information that I requested.
Michael L.
