Wireless
8505 Discusiones
Bluetooth keyboard K850 lacks responsiveness Win11 Pro 24H2
RotaRota
Novato
2.132 Vistas
I have a MiniPC BESSTAR U820 with i5-8279U CPU and Win11 Pro 24H2.
The Logictech K850 Keyboard is connected to Intel Wireless Bluetooth 20.100.10.11.
The keyboard has a significant lag for the first keystroke of a sequence.
I set "svchost.exe" to high priority using the task scheduler at system startup as
proposed in https://learn.microsoft.com/en-us/answers/questions/3866346/bluetooth-devices-in-windows-11-lack-responsivenes?source=docs
Open Task Scheduler > Create Task.
Set trigger at system startup as admin
Under "Actions", use this as the action:
cmd /c wmic process where name="svchost.exe" call setpriority 128
(128 is "High" priority)
Is there a more specific way to set priority for process bthserv?
Does it make sense to set bthserv to RealTime priority?
Is there a newer BT driver e.g. 23...?
Etiquetas (1)
0 kudos
1 Solución
LeonWaksman
Superusuario
1.827 Vistas
@RotaRota
Did you tried to connect your keyboard via Unifying receiver instead the Bluetooth?
Leon
Ver la solución en mensaje original publicado
6 Respuestas
JedG_Intel
Moderador
2.034 Vistas
Hello RotaRota,
To assist you effectively, please share the information below.
1. Have you tested any other Bluetooth devices?
2. Were you able to have wireless connection in a normal/expected performance before?
3. Have you installed any recent software or hardware in your system?
4. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I hope to hear from you soon.
Best regards
Jed G.
RotaRota
Novato
1.944 Vistas
Hi Jed,
sorry for the late response. I was traveling and did not have access to the system
Yes, other BT devices work fine e.g. BT mouse M720 Triathlon
The K850 Keyboard also works fine on other PC e.g. HP Elitebook 860
A USB keyboard works fine. I did never have good performance with the BT keyboard
I update win11 and Intel drivers regularly. Today I tried to install BT 23.160.0,
but it does not look applicable
Yes, it is the built-in Intel native BT.
>5. Please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Report is attached
              Fritz
JedG_Intel
Moderador
1.935 Vistas
Hello RotaRota,
Thank you for sharing all this information.
Upon review, your wireless product Intel Dual Band Wireless-AC 7265 has reached the end of its interactive technical support life. With this in mind, other community members may continue assisting you.
I would like to apologize that I wasn't able to fully support you with your concern but I hope that you understand our position.
You may also check this article for more information: Customer Support Options for Discontinued Intel® Wireless Products
I will also be closing this inquiry. If you have other questions or concerns, please submit a new question as this thread will no longer be monitored.
Best regards
Jed G.
RotaRota
Novato
1.868 Vistas
In addition to setting "svchost.exe" to high priority (as described above)
the responsivenes improved a bit by
1. Uninstall options_installer
2. Uninstall logioptionsplus_installer
3. Install BT-23.40.0-64UWD-Win10-Win11 for A7265
Please be aware that driver version 20.100.10.11 (64-bit) are the last available version of the wireless drivers for these products.
This software has been End of Life and no additional support will be provided to these drivers.
  • Windows® 10 64-bit and Windows 11*:
  • Package version 23.40.0
  • Driver version 20.100.10.11 for 7265 (Rev. D), 3168, 3165
LeonWaksman
Superusuario
1.828 Vistas
@RotaRota
Leon
RotaRota
Novato
1.682 Vistas
@LeonWaksman
Thank you for the hint.
I got a Unifying receiver and disconnected the keyboard/mouse from BT.
Keyboatd and mour work fine with the Unifying receiver
Responder
