Wireless
8787 Discussions
intel centrino can't detect any wifi
陳陳_鼎元
i cannot detect any wifi since i install another os(ubuntu) on my computer
both os cannot detect any
i have check the driver and make sure network card is open
can't figure out why
can any body help me ,plz
As we understand, your PC does not show any wireless networks after you installed Ubuntu on it. Here are few things to consider about this:
- The Linux drivers are part of the upstream Linux* kernel and are available through the regular channels, distributions, or the https://www.kernel.org/ Linux* kernel archives. Linux driver support can be found in the http://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi Linux Community page.
- The process to connect to a Wireless network in Ubuntu is simple if the adapter and driver are working correctly. You can check the following document from Ubuntu Documentation: http://help.ubuntu.com/lts/ubuntu-help/net-wireless-connect.html Connect to a wireless network.
- Make sure that your wireless adapter is enabled. This is normally done with a hardware switch in the chassis, or with a Key combination.
For additional assistance, we will need the Wireless adapter model, OS version, PC model, and any other details you can provide about the issue.
Jonathan
We have not received any updates since our last post, please let us know if you require further assistance.
