- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
My Intel Centrino Wireless-N 1000 network adapter suddenly disappeared from the Device Manager list on my Windows 7 laptop. And then it's reappeared & worked & disappeared again, twice since then. Below this adapter on the Device Manager Network Adapter list there was also Microsoft Virtual WiFi Miniport Adapter & Adapter #2 listed as well--which has also disappeared & reappeared & disappeared again. Do you know the reason for this or if I can somehow force my system to "find" it--without internet? I've run searches & diagnosis tests & always comes up as "wireless network adapter not found". Thank you!
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Let's make sure you are running the latest possible drivers.
Intel has stopped providing downloads for the (long) discontinued Wireless adapters. Luckily, I caught the notice of the driver removal and saved copies of the final packages in my archive. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters. In this case, you want the subfolder named Advanced-N 6200, 6230, 6250 and Wireless-N 100, 130, 1000, 1030, 2200.
If it turns out that you have the latest installed or install it and the problems don't go away, then likely the adapter is in the process of failing. If this is the case, we can discuss possible replacements.
Hope this helps,
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello MNlover
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Isaac Q.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
