Wireless
8722 Discussions
intel jackson peak 1 wifi card UPGRADE
Jonathan1000
I am looking to see what the UPGRADE to a better WiFi card to replace intel jackson peak 1 wifi card that is in a Lenovo Y500 laptop.
AlHill
You should be checking with Lenovo for cards that are supported by their device.
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-io/wireless.html
Jonathan1000
I can't get through to anyone and I cand find this information, I really thought it would be simple enough to upgrade to the WIFI 5 at least but no luck
Sebastian_M_Intel
Hello Jonathan1000,
Please be aware that the installation or use of Intel® Wireless Adapters is subject to country-specific legal regulations. An adapter installed in a system that is being sold on the market doesn't necessarily mean that the same wireless adapter can be used or installed in another system for the above-mentioned reason. As each country may have different regulatory requirements, before you install/change the Wireless Adapter in a system, you must contact the OEM to determine if the adapter you plan to install is approved for use in your system and country. You are required to follow the OEM post-approval requirements. You can check that here:
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless.html
Additionally, if the OEM offers you the compatible wireless cards, they might be able to sell them to you (or at least give you the exact part number), also, they can help you with the installation process and warranty coverage if applicable.
Please check the following link for different OEMs support websites:
https://www.intel.com/content/www/us/en/support/topics/oems.html
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello Jonathan1000,
We hope the previous information was useful to you.
As you should be working with your system manufacturer, we will close this inquiry from our side. If you have any additional questions, please submit a new thread and we will gladly assist you.
Sebastian M
