Wireless
8961 Discussions
intel proset, machine authentication asks windows user credentials
w
Hi all,
I want to authenticate my machine via network policy server (windows radius). When i try to connect, it always asks my windows credentials and after submit it, i can connect the ssid perfectly! But i want my machine to sent only o hostname (not a username/password) and so that (via radius) the active directory can check whether my pc is registered in AD domain computers.
I ve already followed these steps:
1)Use Proset 12.4.3.2 or later
2)Create an ITAdmin package with a PLC+PST profile( i.e. check persistent and prelogon check box) while creating profile thru ITAdmin Profile Wizard.
3)Select Peap as Authentication Type and MSCHAP-v2 as inner tunnel protocol. Use 'Use Secure password' as User Credentials. Uncheck 'For pre-logon connections,....' check-box.
4)Save the package and apply it on the machine where Proset is installed and you want the profile.
thanks for your time,
