Wireless
8552 Discussions
intel wifi 6 ax201 not working
BasheerAbbas
my laptop is Asus TUF Dash f15 , intel WIFI 6 AX201 160MHz , not working .please help me .
BasheerAbbas
ssu
DeividA_Intel
Hello BasheerAbbas,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel Wi-Fi 6 AX201 160MHz.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Can you provide more details about the issue?
4. Do you see any errors in the device manager?
5. Was the adapter working before? When did the issue start?
Deivid A.
BasheerAbbas
Welcome
The device was working, but every day when I turn on the device, the wifi drivers disappears , and the drivers remove from device manager ,
I delete the current driver daily and reinstall the drivers from the Asus site and repeat the process every day.
what i will do ?
DeividA_Intel
Hello BasheerAbbas,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
BasheerAbbas
n_scott_pearson
You need to use the Windows Update Show-Hide tool to block the upgrade of the drivers by Windows Update. I have attached a copy of this tool, but you can get the 'official' version from Microsoft if you so desire.
Hope this helps,
BasheerAbbas
I do this process every day, in the pictures below ...
DeividA_Intel
Hello BasheerAbbas,
Thanks for the information provided. To continue further, try the following:
1. Perform a clean install of the Wi-Fi and Bluetooth Intel drivers:
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Run all the Windows updates, including the optional ones.
Deivid A.
BasheerAbbas
The problem is still
The adapter works after that, but the second day it disappears.
DeividA_Intel
Hello BasheerAbbas,
Thanks for the confirmation. I would like to investigate this issue, I will need an updated report from the Intel® System Support Utility (Intel® SSU):
Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
BasheerAbbas
In the attachment you find the report.
Note: The frequency of the screen changes automatically from 120Hz to 60Hz with the disappearance of the converter.
DeividA_Intel
Hello BasheerAbbas,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello BasheerAbbas,
Thanks for your patience. Based on all the troubleshooting performed so far, my recommendation would be to check with Asus for further recommendations since this may be related to a hardware issue.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
