Wireless
9036 Discussions
intel wifi driver installer problem error
ozenfurkan
Hello intel wifi Intel® Wi-Fi 6 AX201 160MHz
I'm getting this error while updating the driver."One or more problems caused the installation to fail. Please fix the problems and try the installation again." can you help me please. I translated the screenshot in quotes.
n_scott_pearson
Attaching pictures with non-English text does you no good and is a waste of time as we cannot translate it.
I suggest that you do a clean install of the drivers. Here is the process:
  1. If you haven't already, download - but do not install just yet - the desired Bluetooth and Wireless driver packages for your adapter. Here are the current links for downloading these drivers: Wireless: https://www.intel.com/content/www/us/en/download/19351 and Bluetooth: https://www.intel.com/content/www/us/en/download/18649
  2. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Wi-Fi 6 AX201 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an intel driver associated with it. If neither is the case, go to Step 10.
  7. Right click on the entry for Intel Wi-Fi 6 AX201 and uninstall it, choosing to (checkmark) Delete the driver software for this device.
  8. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  9. Go to Step 5.
  10. (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. Ensure you have enabled cleaning of System Files. I recommend that you then checkmark all categories offered, even if no files currently in this category (so it leaves it set up for next invocation).
  11. (Optional but recommended) Clear each of your browsers' cache.
  12. Install the downloaded Bluetooth driver package (my rule: always install Bluetooth first).
  13. Install the downloaded Wireless driver package.
  14. Manually shutdown and reboot your computer.
  15. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  16. Test.
Hope this helps,
jasonmiller11tt
It looks like the driver installation is failing. I'd recommend first uninstalling the current Wi-Fi driver from Device Manager, restarting your PC, and then installing the latest driver from Intel or your laptop manufacturer's support page. If it still fails, please share your device model, Windows version, and the screenshot so the community can help identify the exact cause.
AlHill
@jasonmiller11tt   three and a half years later is a little late to respond to this thread, ddn't you think?
[Success breeds complacency. Complacency breeds failure. (Andy Grove)]
