Wireless
8965 Discussions
intel wireless ac 9560 code 10
Deano89
Hello All,
So this morning my wifi has randomly just stopped working and in the device manager I have the yellow ! With code10, I’ve had a good read and done most of the “fixes” people have advised to do and I’m not getting nowhere…. Has anyone here had the issue and managed to resolve this?
n_scott_pearson
The 'standard' fix for this issue is a fresh install of the Wireless and Bluetooth drivers. Here is my refined process for performing this fresh install:
  1. If you haven't already, download - but do not install just yet - the latest Bluetooth and WiFi drivers for your adapter. Here are links to these drivers: https://downloadcenter.intel.com/download/30542 and https://downloadcenter.intel.com/download/30584
  2. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and Intel Wireless Bluetooth that is present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Wireless-AC 9560 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an intel driver associated with it. If neither is the case, go to Step 10.
  7. Right click on the entry for Intel Wireless-AC 9560 and uninstall it, choosing to (checkmark) Delete the driver software for this device.
  8. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  9. Go to Step 5.
  10. (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. I recommend that you checkmark all categories offered, even if no files currently (so it leaves it set up for next invocation).
  11. (Optional but recommended) Clear each of your browsers' cache.
  12. Install the Bluetooth driver package (my rule: always do Bluetooth first).
  13. Install the Wireless driver package.
  14. Manually shutdown and reboot your computer.
  15. Enable Internet access.
  16. Test.
Hope this helps,
…S
