- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
[ 6.017937] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 6.057193] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id
0x80400 wfpm id 0x80000020
[ 6.057232] iwlwifi 0000:00:14.3: PCI dev 54f0/00e0, rev=0x370,
rfid=0x20112200
[ 6.057236] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[ 6.057334] iwlwifi 0000:00:14.3: Direct firmware load for
iwlwifi-so-a0-fm-c0-89.ucode failed with error -2
[ 6.057343] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 6.057345] iwlwifi 0000:00:14.3: iwlwifi-so-a0-fm-c0-89 is required
[ 6.057347] iwlwifi 0000:00:14.3: check
git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
But I don't find the firmware in linux-firmware.
Greetings
Jose Alberto Reguero
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello jareguero,
To address your concern effectively, please share the information below.
1. Were you able to have wireless connection in a normal/expected performance before?
2. What Firmware and Kernel version are you using?
3. Is this a laptop or desktop system? If laptop, kindly share the full model
4. What adapter model do you have?
5. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Best regards
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the answer. The system is a desktop. It is a ASUS NUC. I change the card that come with it, and put a BE201 card. I am using a fedora 6.16.3 kernel and I try with a 6.17-rc3 also. The card is recognised well. The problem is that the firmware is not found. The firmware that is trying to load, does not exist. I look the latest firmware git, but the firmware does not exist.
Greetings
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
