Wireless
8664 Discussions
my wifi dashboard is disconnected when no device connecting. how can i get to stay active hot spot?
MHall7
ASouz7
halleum,
Have you tried to access Options >> Preferences >> Applications and then check mark " Run this application at startup"? Then, go to the Hotspot tab and make sure the option under Internet connection sharing is checked? Let us know if this helped you.
halleum,
We are following up on this case and we would like to know if you still require assistance?
ASouz7
Halleum,
We would like to know if the information provided previously helped you resolve the issue. Please let us know at your earliest convenience.
MHall7
i can't find any option. finally, i bought wifi sharer. thank you for your help.
